I"m steel using "Customisation Component Code" with Flowcde 4.5.18.
DMX512 is a protocol "close" to RS232.
My aim is that my pupils can manage a moving-head spot with a flowchart.
The hardware is :
- a Matrix board v3.3 (HP488 + 16F887) , an Eblock RS485 (EB062) and an XLR plug.
- a moving-head spot(VDPL1501MHS-W) in 5-channel mode (Pan, Tilt, Dimmer, Coulour, Gobo).
There will be "new" macros (within the RS232 component) :
- Init DMX
- Send Marks and Break
- Send Start Code Null
- Send 1 Data
- Send 8 Datas
That seems to be OK.
Update this post after a full test.
Daniel
3C : DMX512
- Dan81
- Been thanked: 60 times
Re: 3C : DMX512
Sorry, for the little delay.
As written above, the flowchart is made for the Matrix board with 16F887 and an Eblock EB062 (RS485) on port C .
For changing the value of a channel , push a button (Port A) and turn the potentiometer connected on A1( jumper must be on "Analog")
LCD (port B) shows the values.
Comments within Flowchart are in French, sorry
Daniel
Daniel
- minilyre_FC4.fcf
- (26.75 KiB) Downloaded 502 times
