The attached program is something I have put together. It all works as I want it to but have problems rotating the ADC inputs. Is this a bug or something I have done wrong?
Many thanks
Pete
Problem controlling ADC rotary input
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Re: Problem controlling ADC rotary input
I've tried the program here and the ADC inputs sometimes take a second to react to mouse-clicks. But it does not seem too bad to me. I tried replacing the "delay 50ms" icon with 5 separate "delay 10ms" icons and this improved the response a little. You can also reduce this problem by moving the mouse more slowly into the ADC control.
And if you are not running the latest V4.5, then I suggest you upgrade. We did apply a few fixes in this release to help with this issue.
