Is there anyone who will help with below
Type: GPS board EB056-00-1
How do I get one pulse per second output (1PPS)
How to set the jumpers?
I will be very happy if anyone will help.
GPS 1PPS EB056
MonieJacobsen
john hauton
- Been thanked: 2 times
Re: GPS 1PPS EB056
Hi Monie, did you get your board working ok?
I found that it takes quite a while for the 1pps signal to start. If you leave the module somewhere where
it can 'see' the sky, for perhaps 5 minutes, and see if the pulse appears.
Looking at the diagram in the datasheet the pulse signal comes out of pin 6 of the gps module,
which you can route thro j3 (i think) to different pins on the D connector.
Hope this helps
Regards john
Hope this helps
Regards john
MonieJacobsen
Re: GPS 1PPS EB056
Many thanks for your answer John Hauton
Best Regards
Monie Jacobsen
Best Regards
Monie Jacobsen
Best regards,
Monie
Monie
