I am working on a project were I get data from an input (rs-232, CAN, etc) , depending on the data , can be classified in two types , so I have two tables were they can be placed
I need to compare each variable with all the ones that are in the opposite table
I am not expert in C, but I find a routine in assembler that can work for my purposes
My problem is both tables need a starting address but I am afraid of overwriting the ones used by the C code , and also the C code can overwrite later
I there a way of writing in assembler a generic space for both tables?
here is the code I think can help me
movlw 0x60
movwf tabla1 ; assign first address for table1
movlw 0x70
movwf tabla2 ;assign first address for table2
in_comp movf tabla1,W
movwf FSR ; pointer to the first address of table1
movf INDF,w ;data in the first address of table1-->w
movwf temp1 ;w-->temp1 (we need w y FSR)
movf tabla2,W
movwf FSR ;pointer to the first address of table2
movf INDF,w ;data in the first address of table2-->w
subwf temp1,F ;w-temp1-->temp1
btfss STATUS,Z ;¿is zero?
goto different ;NO
goto equal ;SI
different bsf F_COMP_RX; flag tells has found a non coincident byte
return
equal bcf F_COMP_RX ; is 'z', last byte
sublw 'z' ; checks if the data is the last one (z)
btfss STATUS,Z ;¿is the lats one?
goto comp_nofin ; is not 'z'
return
comp_nofin incf tabla1; go to the next address of table1
incf tabla2; go to the next address of table2
goto in_comp ;keeps on comparing
can someone guide me through the process of implementing this code? will this work? is there any other way of doing it? without c or assembler?
Flowcode, pointers, tables, c code and assembler
Re: Flowcode, pointers, tables, c code and assembler
This should be possible using Flowcode arrays or if pushed C code. This would be much simpler then assembler coding.
Flowcode arrays would have to be created and populated with the correct data at the top of your main.
A C code array can be coded to have initial values so you do not have to manually load the values in on start up.
You would then just need a loop in your Flowcode program to cycle through each element of the array and perform a comparison.
