MediaWiki API help
This is an auto-generated MediaWiki Action API documentation page.
action=revisiondelete
(main | revisiondelete)
  • This module requires read rights.
  • This module requires write rights.
  • This module only accepts POST requests.
  • Source: MediaWiki
  • License: GPL-2.0-or-later
Delete and undelete revisions.
Specific parameters:
Other general parameters are available.
type
Type of revision deletion being performed.
This parameter is required.
One of the following values: archive, filearchive, logging, oldimage, revision
target
Page title for the revision deletion, if required for the type.
ids
Identifiers for the revisions to be deleted.
Separate values with | or alternative.
Maximum number of values is 50 (500 for clients that are allowed higher limits).
hide
What to hide for each revision.
Values (separate with | or alternative): comment, content, user
show
What to unhide for each revision.
suppress
Whether to suppress data from administrators as well as others.
One of the following values: no, nochange, yes
Default: nochange
reason
Reason for the deletion or undeletion.
tags
Tags to apply to the entry in the deletion log.
Values (separate with | or alternative): Flowcode v8, Flowcode v9, Flowcode v10, Version
token
A "csrf" token retrieved from action=query&meta=tokens
