User contributions
Jump to navigationJump to search- 17:28, 9 November 2022 diff hist -11 Component: Switch Array (Slide) (Switches) current
- 17:28, 9 November 2022 diff hist -11 Component: Switch Array (Push) (Switches) current
- 17:28, 9 November 2022 diff hist +158 Component: Switch Array Template (Switches) current
- 17:28, 9 November 2022 diff hist -11 Component: Switch (Toggle, PCB) () current
- 17:28, 9 November 2022 diff hist -11 Component: Switch (Slide, PCB) () current
- 17:28, 9 November 2022 diff hist -11 Component: Switch (Toggle, Panel) () current
- 17:28, 9 November 2022 diff hist +160 Component: Switch (Rocker) () current
- 17:28, 9 November 2022 diff hist -11 Component: Switch Illuminated (Push, Panel) () current
- 17:28, 9 November 2022 diff hist -11 Component: Switch (Push, Panel) () current
- 17:28, 9 November 2022 diff hist -185 Component: Switch (Push, PCB, SMT) () current
- 17:28, 9 November 2022 diff hist -11 Component: Switch (Generic) () current
- 17:28, 9 November 2022 diff hist -11 Component: Switch (Push, PCB) () current
- 17:27, 9 November 2022 diff hist -6 Component: Simulation Slide Switch () current
- 17:27, 9 November 2022 diff hist -6 Component: Simulation Push Switch () current
- 17:27, 9 November 2022 diff hist -11 Component: Switch Template (Switch) current
- 17:27, 9 November 2022 diff hist -360 Component: Simulation Switch Template (Controls) current
- 17:27, 9 November 2022 diff hist -192 Component: Rotary Switch (Switch) current
- 17:27, 9 November 2022 diff hist -22 Component: Data Recorder Setup (Runtime Tools) current
- 17:27, 9 November 2022 diff hist -15 Component: Starburst Display (Segment) current
- 17:27, 9 November 2022 diff hist +342 Component: PWM (Internal) (General Output) current
- 17:27, 9 November 2022 diff hist +158 Component: LED (SMD, PCB) () current
- 17:27, 9 November 2022 diff hist -11 Component: LED Array (PCB) () current
- 17:27, 9 November 2022 diff hist -15 Component: 7Segment (Single) (Segment) current
- 17:27, 9 November 2022 diff hist -190 Component: Simulation 7 Seg (Advanced Shapes) current
- 17:27, 9 November 2022 diff hist -15 Component: 7Segment (Quad) (Segment) current
- 17:27, 9 November 2022 diff hist +158 Component: LED (5mm, Panel) () current
- 17:27, 9 November 2022 diff hist -6 Component: Simulation LED (5mm, PCB) () current
- 17:27, 9 November 2022 diff hist +158 Component: LED MultiColour Bi (5mm, PCB) (LED) current
- 17:27, 9 November 2022 diff hist +158 Component: LED (5mm, PCB) () current
- 17:27, 9 November 2022 diff hist -6 Component: Simulation LED (LES, Panel) () current
- 17:27, 9 November 2022 diff hist +160 Component: I2C (CAL) (Misc) current
- 17:27, 9 November 2022 diff hist +158 Component: LED (LES, Panel) () current
- 17:27, 9 November 2022 diff hist -178 Component: Digital Potentiometer (X9Cx0x) (Analog Output) current
- 17:27, 9 November 2022 diff hist -3 Component: RGB Xmas Tree (Misc Circuit) current
- 17:27, 9 November 2022 diff hist -15 Component: 7Segment (Quad TM1637) (Segment) current
- 17:27, 9 November 2022 diff hist -13 Component: LED Multicolour RGB (5mm, PCB) () current
- 17:27, 9 November 2022 diff hist -15 Component: 7Segment (Hex TM1637) (Segment) current
- 17:27, 9 November 2022 diff hist +161 Component: LED (Generic, RGB) (LED) current
- 17:27, 9 November 2022 diff hist -360 Component: Piezo Sounder (Audio Output) current
- 17:27, 9 November 2022 diff hist -786 Component: PWM 16CH 12Bit (PCA9685) (General Output) current
- 17:27, 9 November 2022 diff hist -614 Component: Digital Potentiometer (MCP45XX / MCP46XX) (Analog Output) current
- 17:27, 9 November 2022 diff hist -296 Component: Digital Potentiometer (MCP41XX / MCP42XX) (Analog Output) current
- 17:27, 9 November 2022 diff hist -614 Component: Digital Potentiometer (MCP44XX) (Analog Output) current
- 17:27, 9 November 2022 diff hist -623 Component: RGB LED LP5030 LP5036 (LEDs) current
- 17:27, 9 November 2022 diff hist -1,515 Component: RGB LED WS2811 / WS2812 / APA106 (LEDs) current
- 17:27, 9 November 2022 diff hist -186 Component: Simulation LED Template (Indicators) current
- 17:27, 9 November 2022 diff hist -2,349 Component: RGB LED WS2801 (LEDs) current
- 17:27, 9 November 2022 diff hist -6 Component: Simulation LED (SMD) () current
- 17:27, 9 November 2022 diff hist -1,515 Component: RGB LED SK6812 RGBW (LEDs) current
- 17:27, 9 November 2022 diff hist -11 Component: LED Template (LED) current
