Hi, all
Im still working on my aquarium controller, everything works perfectly but one thing I can't figure out thats why I need your help.
For the temperature controller section of the software I need to make something like hysteresis so that the heater doesn't kick in on every change of temperature.
If I set the upper limit of the temperature to: 22.4
My goal temperature to: 22.0
and my lowest temperature to: 21.8
So that the heater kicks in when the temperature is 22.8 or below and stops when temperature reaches 22.1 or above.
I dont know on howto approach this problem. hope somebody can explain it to my.
Regards Jordy
- Jordy101091
- Has thanked: 25 times
- Been thanked: 188 times
- Has thanked: 1 time
- Been thanked: 30 times
Re: temperature controll
I would try the following, or something similiar
Gary
- if (new_temp-old_temp) > 0 then temp_up = 1
if (new_temp-old_temp) < 0 then temp_up = 0
if new_temp <=22.8 AND temp_up = 0 then heater on
if new_temp >=22.1 AND temp_up = 1 then heater off
Gary
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
I think you just need to do the following every few seconds:
read temperature
if (temperature < MIN_TEMPERATURE)
turn heater on
end if
if (temperature > MAX_TEMPERATURE)
turn heater off
end if
- Jordy101091
Thanks steve and gary for your quick reaction,
The solution steve has works best for me and tested this and works perfectly thanks for that.
Regards Jordy
Regards Jordy
