temperature controll
Jordy101091
Has thanked: 25 times
Been thanked: 188 times
Post by Jordy101091 »
Hi, all
Im still working on my aquarium controller, everything works perfectly but one thing I can't figure out thats why I need your help.
For the temperature controller section of the software I need to make something like hysteresis so that the heater doesn't kick in on every change of temperature.
If I set the upper limit of the temperature to: 22.4
My goal temperature to: 22.0
and my lowest temperature to: 21.8
So that the heater kicks in when the temperature is 22.8 or below and stops when temperature reaches 22.1 or above.
I dont know on howto approach this problem. hope somebody can explain it to my.
Regards Jordy
Gary Freegard
Has thanked: 1 time
Been thanked: 30 times
Re: temperature controll
Post by Gary Freegard »
I would try the following, or something similiar
  • if (new_temp-old_temp) > 0 then temp_up = 1
    if (new_temp-old_temp) < 0 then temp_up = 0
    if new_temp <=22.8 AND temp_up = 0 then heater on
    if new_temp >=22.1 AND temp_up = 1 then heater off
Goodluck
Gary
I think you just need to do the following every few seconds:
  read temperature
  if (temperature < MIN_TEMPERATURE)
    turn heater on
  end if
  if (temperature > MAX_TEMPERATURE)
    turn heater off
  end if
Jordy101091
Thanks steve and gary for your quick reaction,
The solution steve has works best for me and tested this and works perfectly thanks for that.
Regards Jordy
