EB 072 - ZIF socket NOT works
Monie Jacobsen
Has thanked: 17 times
Been thanked: 46 times
Post by Monie Jacobsen »
Is there someone here can help me with below?
I have bought EB 072 - ZIF socket
Have inserted EB 072 - ZIF properly EB-006-00-7 Board Multi Programs.
Bat unit EB072 - ZIF socket, but will not work.
Is there anyone here who can help me?
Best Regard
Monie
Steve001
Has thanked: 460 times
Been thanked: 523 times
Re: EB 072 - ZIF socket NOT works
Post by Steve001 »
When the ZIF socket is attached to the EB006, the I/O is no longer available for use and the device becomes solely a programmer.
http://www.matrixmultimedia.com/resourc ... 2-30-1.pdf
see page 4 also are the chip selection jumpers correct for your device ?
Monie Jacobsen
HI Steve001
I've tried with PIC16F877A but not works!
Also jump to 40 PIN is connect!
Best Regard
Monie
Enamul
Has thanked: 271 times
Been thanked: 814 times
Post by Enamul »
Note that this board is designed only for programming
5V, 8-bit PIC chips, the clock and port connections are not
routed through from the EB006 to the ZIF board so you
cannot run your application from here.
What do you mean by "not works"
Enamul
University of Nottingham
enamul4mm@gmail.com
Monie Jacobsen
HI Enamul
OK, With att this board is designed only for programming.
Many thanks for your help.
Enamul, you will remember PIC18F4685 so we can use this IC
Best Regard
Monie
Enamul
Post by Enamul »
Yes, I have ordered two chips which are on the way. I will let you know as soon as those arrive.
Enamul
enamul4mm@gmail.com
