Is there someone here can help me with below?
I have bought EB 072 - ZIF socket
Have inserted EB 072 - ZIF properly EB-006-00-7 Board Multi Programs.
Bat unit EB072 - ZIF socket, but will not work.
Is there anyone here who can help me?
EB 072 - ZIF socket NOT works
- Has thanked: 17 times
- Been thanked: 46 times
- Has thanked: 460 times
- Been thanked: 523 times
Re: EB 072 - ZIF socket NOT works
When the ZIF socket is attached to the EB006, the I/O is no longer available for use and the device becomes solely a programmer.
http://www.matrixmultimedia.com/resourc ... 2-30-1.pdf
see page 4 also are the chip selection jumpers correct for your device ?
HI Steve001
I've tried with PIC16F877A but not works!
Also jump to 40 PIN is connect!
Best Regard
Monie
Monie
- Enamul
- Has thanked: 271 times
- Been thanked: 814 times
What do you mean by "not works"Note that this board is designed only for programming
5V, 8-bit PIC chips, the clock and port connections are not
routed through from the EB006 to the ZIF board so you
cannot run your application from here.
HI Enamul
OK, With att this board is designed only for programming.
Many thanks for your help.
Enamul, you will remember PIC18F4685 so we can use this IC
Best Regard
Monie
Monie
- Enamul
Yes, I have ordered two chips which are on the way. I will let you know as soon as those arrive.Enamul, you will remember PIC18F4685 so we can use this IC
