Capture on CCP1
waligator
Has thanked: 5 times
Been thanked: 7 times
Capture on CCP1
Post by waligator »
Hi all,
To begin to understand the function capture of the timer 1, I would at every rising edge on pin CCP1, my variable is incremented.
I will post the beginning of pragramme but never increment the counter.
Someone could help me.
tmr1 CCP1 capture.fcf
(14 KiB) Downloaded 299 times
Enamul
Has thanked: 271 times
Been thanked: 814 times
Re: Capture on CCP1
Post by Enamul »
I have tried couple of months back the capture function and can't mange to sort that. Not was quite sure why but will have a look again and let you know.
Enamul
University of Nottingham
enamul4mm@gmail.com
waligator
Re: Capture on CCP1
Post by waligator »
Yes, it must be a bad command. I can not find it. Precision, I use a 16F876A.
waligator
Re: Capture on CCP1
Post by waligator »
It's good, it works. :D I made a syntax error when the macro "capture" is called. :oops:
The problem is fixed and it works well as a pulse counter.
(14 KiB) Downloaded 362 times
ProtonLaser
Has thanked: 6 times
Been thanked: 2 times
Re: Capture on CCP1
Post by ProtonLaser »
Yes but hae you tried capturing the timer value???
Re: Capture on CCP1
ProtonLaser wrote:Yes but hae you tried capturing the timer value???
I have done that for you in this post:
http://www.matrixmultimedia.com/mmforum ... 052#p46225
ProtonLaser
Re: Capture on CCP1
Yes i tryed it and it did not capture the timers values.
**Tryed the version you proposed, worked great!!
Thank you again Martin for giving a solution!!
I will give the timer option again and come back.
Abel
