Hi all,
To begin to understand the function capture of the timer 1, I would at every rising edge on pin CCP1, my variable is incremented.
I will post the beginning of pragramme but never increment the counter.
Someone could help me.
Capture on CCP1
- Enamul
- Has thanked: 271 times
- Been thanked: 814 times
Re: Capture on CCP1
I have tried couple of months back the capture function and can't mange to sort that. Not was quite sure why but will have a look again and let you know.
Re: Capture on CCP1
It's good, it works.
I made a syntax error when the macro "capture" is called.
The problem is fixed and it works well as a pulse counter.
- tmr1 CCP1 capture.fcf
- (14 KiB) Downloaded 349 times
- Has thanked: 6 times
- Been thanked: 2 times
Re: Capture on CCP1
I have done that for you in this post:ProtonLaser wrote:Yes but hae you tried capturing the timer value???
http://www.matrixmultimedia.com/mmforum ... 052#p46225
Re: Capture on CCP1
Yes i tryed it and it did not capture the timers values.
**Tryed the version you proposed, worked great!!
Thank you again Martin for giving a solution!!
I will give the timer option again and come back.
Abel
Abel
