I may be doing something wrong, but the component macro "get average byte" seems to hang the programme attached. The offending bit is commented and is in the macro "sign_get", Ive tried using the "get byte" instead and this works fine. Ive also tried disabling Timer 1 just before and re-enabling after the component macro. The problem still exists, the system simulates fine but does NOT work in the hardware.
Chris
Problem with Average analogue component macro?
Chris_MIRA
- Has thanked: 2 times
- Been thanked: 21 times
- Flasher and Brake Debug.fcfx
- (39.41 KiB) Downloaded 304 times
hyperion007
- Has thanked: 49 times
- Been thanked: 101 times
Re: Problem with Average analogue component macro?
I've had similar problems with the dsPICs and the average ADC macros. Both the Get Average and Raw Average functions made the program freeze up. Worked fine on 8 bit PICs but not 16 bit.
The Get Byte or Get Int worked fine if I remember correctly.
Also, you can try to increase the delay from 2us to maybe 200 or 2000us just to test it out.
Chris_MIRA
Sorry to push, but is there any progress on this? (Im now confident it is a bug as others have experienced the same problem)
Chris
Chris
Hi Chris,
Please can you give this file a go, it seems to be working well for me.
The file needs to live here "C:\Program Files (x86)\Flowcode 6\CAL\PIC16BIT".
Chris_MIRA
All working properly now (thanks for your help
Chris
Chris
