Problem with Average analogue component macro?
Chris_MIRA
Has thanked: 2 times
Been thanked: 21 times
Post by Chris_MIRA »
I may be doing something wrong, but the component macro "get average byte" seems to hang the programme attached. The offending bit is commented and is in the macro "sign_get", Ive tried using the "get byte" instead and this works fine. Ive also tried disabling Timer 1 just before and re-enabling after the component macro. The problem still exists, the system simulates fine but does NOT work in the hardware.
Chris
Flasher and Brake Debug.fcfx
(39.41 KiB) Downloaded 304 times
hyperion007
Has thanked: 49 times
Been thanked: 101 times
Re: Problem with Average analogue component macro?
Post by hyperion007 »
I've had similar problems with the dsPICs and the average ADC macros. Both the Get Average and Raw Average functions made the program freeze up. Worked fine on 8 bit PICs but not 16 bit.
The Get Byte or Get Int worked fine if I remember correctly.
Also, you can try to increase the delay from 2us to maybe 200 or 2000us just to test it out.
Chris_MIRA
Sorry to push, but is there any progress on this? (Im now confident it is a bug as others have experienced the same problem)
Chris
Hi Chris,
Please can you give this file a go, it seems to be working well for me.
PIC16BIT_CAL_ADC.c
(37.22 KiB) Downloaded 328 times
The file needs to live here "C:\Program Files (x86)\Flowcode 6\CAL\PIC16BIT".
Chris_MIRA
All working properly now (thanks for your help :-) )
Chris
