compiler hex avr pwm bug flowcodde 6.1.3
hi,
Urgent new version 6.1.3
Updated pwm flowcode 6.1.3
Bug compilation Avr
Bug compilation Avr
Re: compiler hex avr pwm bug flowcodde 6.1.3
hi,
it works version 6.1.2
now it impossible to compile in hex avr
bruno
bruno
- TP_MOTEURDC_prof_v6.fcfx
- (9.06 KiB) Downloaded 588 times
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
This is odd, your project compiles OK on my installation.
I have attached the latest copies of PWM component, to go into your Flowcode installation directory ..\components
and of the AVR_CAL_PWM.c to go into your Flowcode installation directory ..\CAL\AVR
Please make a backup of your versions and then replace with these and see if it fixes the issue.
Leigh
Leigh
- PWM.fcpx
- (7.82 KiB) Downloaded 528 times
- AVR_CAL_PWM.c
- (20.03 KiB) Downloaded 632 times
hi,
it doesn't work
in .c no ok , in .hex no ok error =1
bruno
it doesn't work
bruno
Hi Bruno,
Working fine for me too.
I would recommend that you uninstall Flowcode, delete the "Flowcode 6" folder from Program Files (x86) and then reinstall the latest release 6.1.3.
Deleting the folder will clear out any potential files that shouldn't be there which could be upsetting the compiler.
Hopefully this should solve the problem for you.
hi,
I have uninstalled and then 6.1.3.2 flowcode
I passed in 6.1.0 it is ok *.hex
when I install the patch 6.1.3.2 does not work
bruno
bruno
hi,
I managed to work, I gave an old file and that's ok
bruno
bruno
- AVR_CAL_PWM.c
- (19.23 KiB) Downloaded 590 times
- LeighM
Hi Bruno
Thanks for letting us know that it is now working.
It is strange though, this seems to imply that your Flowcode installation is also using an older version of the PWM component.
Could you send your generated C file TP_MOTEURDC_prof_v6.c?
Also do you have any additional component paths set?
(In View->Global Options->Locations->”Look for components in…”)
Thanks,
Leigh
Thanks,
Leigh
hi,
I just tested the installation another PC, no problem ,this is my pc
- TP_MOTEURDC_prof_v6.c
- (19.6 KiB) Downloaded 545 times
- LeighM
Thanks for that, it definitely shows that your PC installation is using an older version of the PWM Flowcode component (PWM.fcpx).
A couple of possibilities are:
1) Do you have any additional component paths set? (In View->Global Options->Locations->”Look for components in…”)
2) Have you saved or renamed an older PWM.fcpx file in the components directory?
