compiler hex avr pwm bug flowcodde 6.1.3
coffy
Been thanked: 3 times
Post by coffy »
hi,
Urgent new version 6.1.3
Updated pwm flowcode 6.1.3
Bug compilation Avr
(64.49 KiB) Downloaded 7284 times
Has thanked: 481 times
Been thanked: 699 times
Re: compiler hex avr pwm bug flowcodde 6.1.3
Could you attach your Flowcode project file?
Or PM it.
Thanks.
Leigh
coffy
Post by coffy »
hi,
it works version 6.1.2 :evil: :evil:
now it impossible to compile in hex avr
bruno
TP_MOTEURDC_prof_v6.fcfx
(9.06 KiB) Downloaded 437 times
This is odd, your project compiles OK on my installation.
I have attached the latest copies of PWM component, to go into your Flowcode installation directory ..\components
and of the AVR_CAL_PWM.c to go into your Flowcode installation directory ..\CAL\AVR
Please make a backup of your versions and then replace with these and see if it fixes the issue.
Leigh
PWM.fcpx
(7.82 KiB) Downloaded 406 times
AVR_CAL_PWM.c
(20.03 KiB) Downloaded 502 times
coffy
Post by coffy »
hi,
it doesn't work
in .c no ok , in .hex no ok error =1
bruno :oops:
Hi Bruno,
Working fine for me too.
I would recommend that you uninstall Flowcode, delete the "Flowcode 6" folder from Program Files (x86) and then reinstall the latest release 6.1.3.
Deleting the folder will clear out any potential files that shouldn't be there which could be upsetting the compiler.
Hopefully this should solve the problem for you.
coffy
Post by coffy »
hi,
I have uninstalled and then 6.1.3.2 flowcode
I passed in 6.1.0 it is ok *.hex :D :D
when I install the patch 6.1.3.2 does not work :( :(
bruno
Did you try a fresh new full install of FlowCode_6.1.3.2_full.msi ?
coffy
Post by coffy »
hi,
no, I'll test and tell you if it is ok.
bruno
coffy
Post by coffy »
hi,
I tested, it does not work !!!!
:twisted: :twisted: :evil: :evil: :evil:
bruno
coffy
Post by coffy »
hi,
I managed to work, I gave an old file and that's ok :roll: :roll:
bruno
AVR_CAL_PWM.c
(19.23 KiB) Downloaded 458 times
Hi Bruno
Thanks for letting us know that it is now working.
It is strange though, this seems to imply that your Flowcode installation is also using an older version of the PWM component.
Could you send your generated C file TP_MOTEURDC_prof_v6.c?
Also do you have any additional component paths set?
(In View->Global Options->Locations->”Look for components in…”)
Thanks,
Leigh
coffy
Post by coffy »
hi,
I just tested the installation another PC, no problem ,this is my pc
(19.6 KiB) Downloaded 418 times
Thanks for that, it definitely shows that your PC installation is using an older version of the PWM Flowcode component (PWM.fcpx).
A couple of possibilities are:
1) Do you have any additional component paths set? (In View->Global Options->Locations->”Look for components in…”)
2) Have you saved or renamed an older PWM.fcpx file in the components directory?
