AVR Enc28J60 compiler stop ::Component.Property .GetValue
Rudi
Has thanked: 493 times
Been thanked: 187 times
Post by Rudi »
Arduino Mega 2560 R3
Enc28J60
basis
hi guys
have a try in the base and after i change the few arguments to the port var then compiled
after try to use the properties port and not the static unsigned MyPort Var, it stop compile at this.
i think there is not wrong with the api - not sure is this a bug - i used the api from wiki like describt.
simulation is ok with this api get, but can not compile with this
MyPort = ::Component .Property .GetValue (TCPIP_ENC28J60,"Port")
if i use
MyPort = 80
it compile and run like it must,
only stop with this GetValue..
thanks for help
best wishes
rudi ;-)
Re: AVR Enc28J60 compiler stop ::Component.Property .GetValu
Hi Rudi,
Yes I imagine that works well for sim but not for download.
You either need to make MyPort into a property instead of a variable or you need to use the AddVar event to populate the variable with the right initialiser value on Compile time.
If you want an example of this then let us know and I'll make you one up.
Rudi
Post by Rudi »
[no hurry!]
hi benj,
txs!
ok - i have try :)
// compile to c ok, but compile to hex not:
.Expansion = "MX_GLOBAL MX_UINT16 FCV_MYPORT = (" + ::Component .Property .GetValue (TCPIP_ENC28J60,"Port")
.Expansion = .Expansion + ");\n"
c code
MX_GLOBAL MX_UINT16 FCV_MYPORT = (80);
looks good and bad :oops:
i will try later again, not sure what i make wrong.
have test more variation -
base:
i have in projekt the FCV_MYPORT in project explorer as Global Var
in TCPIP_ENC28J60 Properties i will use the String Var "Port" and fill it with 80
in the flowchart i use FCV_MYPORT in each function. so the port can be variable setup in panel properties.
i try then to get the properties var value to the FCV_MYPORT with this.
in compile to c it looks good.
in compile to hex there is a mistake.
btw:
what means
.Expandname
thank you for show the right way
best wishes
rudi ;-)
LeighM
Has thanked: 481 times
Been thanked: 699 times
Post by LeighM »
Hi Rudi,
There is a simple way to do this, see if this does what you want ...
Which creates this C code ...
Hope that helps,
Leigh
Rudi
Post by Rudi »
hi leigh
why complicate things when it just goes.
I embrace you - you saved the weekend and many test hour.
best wishes
rudi ;-)
edit:
these add var possibility I'll try again later.
For this process is sufficient like you taught
btw:
you can created via the project explorer variable and the panel vars bring
together in a spreadsheet? ( yes..I think I repeat my just learned - i am happy for the weekend ( pause ) ;-) )
LeighM
Post by LeighM »
Hi Rudi,
If you want to load a Flowcode variable (rather than C define as my previous example) then try this ...
which creates this C code ...
MX_GLOBAL MX_UINT16 FCV_VARPORT;
	// Calculation:
	//  VarPort = MYPORT
	FCV_VARPORT = 80;
Leigh
LeighM
Post by LeighM »
Just remember properties have two names, "title" (or cosmetic name) and "variable",
"variable" name is used for calculations ...
