Enc28J60
basis
hi guys
have a try in the base and after i change the few arguments to the port var then compiled
after try to use the properties port and not the static unsigned MyPort Var, it stop compile at this.
i think there is not wrong with the api - not sure is this a bug - i used the api from wiki like describt.
simulation is ok with this api get, but can not compile with this
MyPort = ::Component .Property .GetValue (TCPIP_ENC28J60,"Port")
MyPort = 80
only stop with this GetValue..
thanks for help
best wishes
rudi
