delay function problem
howard123
Has thanked: 30 times
Been thanked: 28 times
Post by howard123 »
Hello all
Not sure if this should be in the bug report but I am having strange behaviour when using the delay function in conjunction with a UART.
As you can see from the flowcode image a 4mS delay is placed between UART sends but on the logic analyser image, measuring target hardware, it is actually 2mS. This is with a baud rate of 9600. Changing the baud rate to a higher speed makes the delay longer and it gets close to 4mS at 115200.
My clock is defined correctly at 16MHz.
Many thanks
Howard
FC 7.2.0.5
PIC18F46K22
logic ana.JPG (34.48 KiB) Viewed 4986 times
Bachman
Has thanked: 9 times
Been thanked: 53 times
Re: delay function problem
Post by Bachman »
The flowchart command sends the charaters to a buffer (SW, HW, both?) then waits 4 ms, the main process does not wait for the UART module to finish the job. This is why you see more pause at higher UART baudrate. I think.
Delay time.jpg (36.14 KiB) Viewed 4970 times
howard123
Post by howard123 »
Thanks I understand now
howard
Hi Howard,
If you wanted to wait until the UART byte has finished being sent before starting your delay then you could use this following C code in a C icon.
UART Channel 1
while (TXSTA1bits.TRMT);
UART Channel 2
while (TXSTA2bits.TRMT);
