pROBLEM WITH 12f629
pROBLEM WITH 12f629
I have multiple projects with FC6 and FC7 with chips 16F877, atmega32 etc, and everything works fine.
But I'm having problem with 12F629. Could somebody take a look and tell me why my program is not working. It is working fine with atmega32 and 16F877.
THX
THX
- Webasto1.fcfx
- (6.6 KiB) Downloaded 319 times
Re: pROBLEM WITH 12f629
Hi dedajozo,
In what way is your project not working?
LED not light at all?
Can you post a full circuit diagram showing how the switches are wired.
Also have you tried one second flasher to make sure hardware is running at the correct speed?
If LED not on when expected, can you measure the voltages of GP0 to GP2 and make sure they are as expected.
Hello Medelec,
I dont know why but it dont works. Now I tried to make same program on attiny13 and when I test it on Easy AVR board, it works normaly, but when I put it on experimental board it doesnt work.
Also when I trie to recompile my old program with FC7, but program is made in FC6, it doesnt work. Only works when I compile it with FC6.
I also tried with attiny 2313 works on AVR board but dont work on my experimental board. What am I doing wrong.
- Webasto.fcfx
- (10.29 KiB) Downloaded 340 times
- webasto (1).jpg (21.44 KiB) Viewed 12872 times
So when you compile the same flowchart with FC6 hardware works.
When compile with FC7 hardware does not work.
Is that correct?
Also you have not got pull down resistors on any of the switches,
It's vital they are fitted!
Is that correct?
This program doesnt work either on FC6 or FC7. I put resistors just didnt draw it on schematics.
Other program works when I compile it wit FC6 an when compile with FC7 doesnt work.
For pull-down resistors see https://www.flowcode.co.uk/wikiv7/index. ... _Switches)
Also there needs to be a current limiting resistor connected to LED
Here is picture where you can see that it is working on EASY AVR board , but when I put it on experimental board it doesnt work.
- file-1_Easy-Resize.com.jpg (93.09 KiB) Viewed 12867 times
But what do you think about compiling error?
File is in the atachment. FC6 copmiling working normaly FC7 doesnt work.
- flasher austrija.fcfx
- (10.1 KiB) Downloaded 306 times
WOW that's a bright LED
Maybe try to apply the fixes posted here and hopefully this will solve things for you.
viewtopic.php?f=63&t=18760
What compilation errors are you getting. Just tested the file and it's compiling correctly for me in v7.FC6 copmiling working normaly FC7 doesnt work.
I Can't get FC6 to compile as I get:
Could not compile with properties or supplementary code fix.
Starting preprocessor: "C:\Program Files (x86)\Flowcode 6\compilers\pic\boostc\pp.exe" "flasher austrija.c" -i "C:\Program Files (x86)\Flowcode 6\compilers\pic\boostc\include" -d _PIC12F609 -la -c2 -o "flasher austrija.pp" -v -d _BOOSTC -d _PIC16 -d _CHAR_INDEX
flasher austrija.c(136:25): error: unknown identifier 'FCP_TRIS_A'
flasher austrija.c(136:25): error: invalid operand 'FCP_TRIS_A'
flasher austrija.c(136:36): error: failed to generate expression
flasher austrija.c(136:56): error: unknown identifier 'FCP_PORT_A'
flasher austrija.c(136:56): error: invalid operand 'FCP_PORT_A'
flasher austrija.c(136:67): error: failed to generate expression
flasher austrija.c(136:56): internal error: failed to generate conditional expression
flasher austrija.c(136:53): error: failed to generate expression
flasher austrija.c(146:29): error: unknown identifier 'FCP_TRIS_A'
flasher austrija.c(146:29): error: invalid operand 'FCP_TRIS_A'
flasher austrija.c(146:40): error: failed to generate expression
flasher austrija.c(146:60): error: unknown identifier 'FCP_PORT_A'
flasher austrija.c(146:60): error: invalid operand 'FCP_PORT_A'
flasher austrija.c(146:71): error: failed to generate expression
flasher austrija.c(146:60): internal error: failed to generate conditional expression
flasher austrija.c(146:57): error: failed to generate expression
flasher austrija.c(171:25): error: unknown identifier 'FCP_TRIS_A'
flasher austrija.c(171:25): error: invalid operand 'FCP_TRIS_A'
flasher austrija.c(171:36): error: failed to generate expression
flasher austrija.c(171:56): error: unknown identifier 'FCP_PORT_A'
flasher austrija.c(171:56): error: invalid operand 'FCP_PORT_A'
flasher austrija.c(171:67): error: failed to generate expression
flasher austrija.c(171:56): internal error: failed to generate conditional expression
flasher austrija.c(171:53): error: failed to generate expression
flasher austrija.c(181:29): error: unknown identifier 'FCP_TRIS_A'
flasher austrija.c(181:29): error: invalid operand 'FCP_TRIS_A'
flasher austrija.c(181:40): error: failed to generate expression
flasher austrija.c(181:60): error: unknown identifier 'FCP_PORT_A'
flasher austrija.c(181:60): error: invalid operand 'FCP_PORT_A'
flasher austrija.c(181:71): error: failed to generate expression
flasher austrija.c(181:60): internal error: failed to generate conditional expression
flasher austrija.c(181:57): error: failed to generate expression
flasher austrija.c(206:25): error: unknown identifier 'FCP_TRIS_A'
flasher austrija.c(206:25): error: invalid operand 'FCP_TRIS_A'
flasher austrija.c(206:36): error: failed to generate expression
flasher austrija.c(206:57): error: unknown identifier 'FCP_PORT_A'
flasher austrija.c(206:57): error: invalid operand 'FCP_PORT_A'
flasher austrija.c(206:68): error: failed to generate expression
flasher austrija.c(206:57): internal error: failed to generate conditional expression
flasher austrija.c(206:54): error: failed to generate expression
flasher austrija.c(216:29): error: unknown identifier 'FCP_TRIS_A'
flasher austrija.c(216:29): error: invalid operand 'FCP_TRIS_A'
flasher austrija.c(216:40): error: failed to generate expression
flasher austrija.c(216:61): error: unknown identifier 'FCP_PORT_A'
flasher austrija.c(216:61): error: invalid operand 'FCP_PORT_A'
flasher austrija.c(216:72): error: failed to generate expression
flasher austrija.c(216:61): internal error: failed to generate conditional expression
flasher austrija.c(216:58): error: failed to generate expression
flasher austrija.c success
failure
Completed BoostC compilation, return = 1
Hello Medelec,
I compile it normaly with FC6 and FC7. But cant get it work when compiled in FC7.
- (160.27 KiB) Downloaded 5989 times
Problem with 12F629 still actual.
I tried few projects with this chip and program doesnt work when compiled with FC7, works normaly when compiled with FC6.
Enybody came on that problem ?
Hi. I don't know about code, but this PIC has some silicon anomalies, and Microchip has published errata files on it. Maybe some of that is causing you issues.
http://ww1.microchip.com/downloads/en/D ... 80125H.pdf
http://ww1.microchip.com/downloads/en/D ... 80329B.pdf
