error programming arduino
achillis1
Has thanked: 91 times
Been thanked: 8 times
Post by achillis1 »
What ever code I use from blank code to just on/off led I get error message!
I am attaching below :)
Thank you
Best Regards
Andreas Achilleos
matrixError.txt
(3.08 KiB) Downloaded 305 times
LeighM
Has thanked: 481 times
Been thanked: 699 times
Re: error programming arduino
Post by LeighM »
Maybe you have not set the Virtual Serial Port for the Arduino board, see the Flowcode Menu...
Build->Project Options->General Options->Programmer Port
achillis1
Post by achillis1 »
All set correctly here! I have tried with 2 different boards. I used before flowcode with arduino with success I do not know why now displays this error message!
achillis1
Post by achillis1 »
Hello LeighM
I have changed the arduino Mega 2560 to Mega 2560 R3 and it worked .. so I guess was my fault!
How ever I want to program an arduino UNO wifi, which board should I choose to be correct? Because the target controller list does not include UNO wifi!
Thank you ,
I am sorry for the inconvinience
LeighM
Post by LeighM »
I don't know for sure, but I would guess start by trying Uno PDIP
achillis1
Post by achillis1 »
Hello Leigh,
Will try that! One important thing though if you can help me in this post.
> Arduino UNO wifi has embedded the ESP8266 and as far as I know in order for the arduino to communicate with esp8266 uses different coding and method and probably uses different UART.
Do you have any recommendations for that ? How to design the flowcode?
Thank you
Best Regards
LeighM
Post by LeighM »
I don't know about that until we get hold of one to play with
achillis1
Post by achillis1 »
Yes you are wright but probably arduino has retired that so maybe is best to play with one of these? :)
https://store.arduino.cc/usa/arduino-mkr1000
Cheers!
