dspMIAC Bluetooth
gavo4
Been thanked: 8 times
dspMIAC Bluetooth
Post by gavo4 »
Hi All,
Has anyone played with the BT Module inside the dspMIAC?, does anyone have some sample code?
Gavin
Re: dspMIAC Bluetooth
Hi Gavin,
Assuming you're using Flowcode 8, Please can you try this and let us know how you get on.
MIAC_dsPIC_Bluetooth.fcfx
(11.17 KiB) Downloaded 386 times
gavo4
Post by gavo4 »
Thanks Benj!,
Will give it a go tomorrow..;-)
gavo4
Post by gavo4 »
Hi Benj,
Please see attached Screen Grab of the Set-Up, I assume the Baud rate is 115200?
LeighM
Has thanked: 481 times
Been thanked: 699 times
Post by LeighM »
57600
TX E.4
RX E.3
Flow Control Off
gavo4
Post by gavo4 »
Thanks Leigh,
Still no connection, keeps saying FAIL, I also can't see the BT module in my "search" on my BT Terminal program
Any ideas what else I should check?
Gavin
LeighM
Post by LeighM »
Hi Gavin,
Might be worth just giving the MIAC a test.
Could you load the attached test program using mLoader
On running the program, the MIAC should display the message "MI8759 dsPIC + BT" if all is well and the Bluetooth module has been detected.
Leigh
MIAC_dsPIC_InputOutput.hex
(40.9 KiB) Downloaded 360 times
gavo4
Post by gavo4 »
Hi Leigh,
It only says MI5809 dsPIC
F1 for Input Test
F2 for Output Test
No BT
Gavin
LeighM
Post by LeighM »
Oh, that's not a good start then :roll:
If it was bought as a Bluetooth version MI8759, then it should look like this inside,
the Bluetooth module is on the right between the two white support pillars
To open the unit, pull at the sides slightly to release the top cover catches,
then pull off the top cover whilst pressing on the key pad to push the top pcb out of the cover.
gavo4
Post by gavo4 »
Hi Leigh,
I opened the unit and saw the blue LED flashing on/off every 2-3 seconds. I tried both your code and the one from Benj with the no response from the BT module.
I have ordered any BT Miac so I will wait test that one incase something is no right with the hardware,
Gavin
LeighM
Post by LeighM »
Also worth checking that the two sets of jumper links are as in the photo
gavo4
Post by gavo4 »
Thanks Leigh,
I did check that as well and all is in order,
Gavin
LeighM
Post by LeighM »
Here's another Bluetooth test program, this one checks the baud rate.
Leigh
MIAC (dsPIC) HP1001 (RN4677) Bluetooth setup.hex
(41.64 KiB) Downloaded 295 times
gavo4
Post by gavo4 »
Hi Leigh,
Its working 100%, I also loaded the code from Benj and now it also working,
Thanks allot!,
I would love to see the code the BT Setup..;-)
Gavin
LeighM
Post by LeighM »
Hi Gavin,
Thanks for the update, glad to hear it is working now :D
Setup program source attached.
It's an (old) Flowcode V6 program that was written prior to the CAL component property expose changes.
So when you load it into V8 the UART properties will all be incorrect.
I've not got around to fixing all that yet :roll:
But if you check and fix the UART properties all should be well
Leigh
MIAC (dsPIC) HP1001 (RN4677) Bluetooth setup.fcfx
(34.97 KiB) Downloaded 284 times
