Pwm not work
Serhii
Been thanked: 1 time
Pwm not work
Post by Serhii »
Hi everyone. There is a problem with compiling the program with the PWM element. Returns lines:
D:\Projects\TRIMMI~1>"C:\PROGRA~2\Flowcode\Common\COMPIL~1\avr\BATCHF~1\..\bin\avr-gcc.exe" -mmcu=atmega328p -Os -ffunction-sections -fdata-sections -funsigned-char -o "D:\Projects\TRIMMI~1\Flowcode1.elf" "D:\Projects\TRIMMI~1\Flowcode1.c" -lm -Wl,-gc-sections
In file included from C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\includes.c:561,
from D:\Projects\TRIMMI~1\Flowcode1.c:249:
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\/AVR\AVR_CAL_PWM.c:110:5: warning: #warning "PWM Channel Uses Resource Timer 0"
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\/AVR\AVR_CAL_PWM.c:495:3: warning: #warning "Period control register not available on target device, period will default to 255 + 1"
What is wrong ?
mnf
Has thanked: 70 times
Been thanked: 440 times
Re: Pwm not work
Post by mnf »
Hi Serhii,
Please post a copy of your program and details of hardware etc
You can add attachments using the tab just below the message box...
Serhii
Re: Pwm not work
Post by Serhii »
Hi Martin. I use chip ATMega 328p (Arduino UNO and Arduino nano). However, as I read in the file CAL_AVR_PWM this chip is not used in it, but only XMEGA and Tiny. Could that be a problem?
Flowcode1.fcfx
(10.66 KiB) Downloaded 419 times
Flowcode1.c
(28.37 KiB) Downloaded 377 times
(279.1 KiB) Downloaded 2968 times
mnf
Re: Pwm not work
Post by mnf »
Timer 0 is an 8 bit timer.
Using Timer1 (choose a different channel) allows alteration and compiles ok. It may be a bug or it may be because Timer 0 is used for delay timing purposes.
Re: Pwm not work
What is wrong ?
Nothing wrong just a warning that if you try and change the period using the PWM properties or the ChangePeriod component macro that it won't do anything as the "Period control register not available on target device" and the "period will default to 255 + 1"
Basically the channel you have selected uses a timer that doesn't support variable periods. Other channels using other timers will work fine.
Serhii
Re: Pwm not work
Post by Serhii »
Ok Benj, I will try it in the device.
Serhii
Re: Pwm not work
Post by Serhii »
Hi Benj. All right, I don't understand why the PWM initially refused to work, may not be the correct parameters set and the warning scared me? Don't know, but now everything works as it should)) Thanks for the help. Have a nice day!
Serhii
Re: Pwm not work
Post by Serhii »
Hi Martin. All right, may not be the correct parameters set and the warning scared me?)) But now everything works as it should)) Thanks for the help. Have a nice day!
