Hi everyone. There is a problem with compiling the program with the PWM element. Returns lines:
D:\Projects\TRIMMI~1>"C:\PROGRA~2\Flowcode\Common\COMPIL~1\avr\BATCHF~1\..\bin\avr-gcc.exe" -mmcu=atmega328p -Os -ffunction-sections -fdata-sections -funsigned-char -o "D:\Projects\TRIMMI~1\Flowcode1.elf" "D:\Projects\TRIMMI~1\Flowcode1.c" -lm -Wl,-gc-sections
In file included from C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\includes.c:561,
from D:\Projects\TRIMMI~1\Flowcode1.c:249:
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\/AVR\AVR_CAL_PWM.c:110:5: warning: #warning "PWM Channel Uses Resource Timer 0"
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\/AVR\AVR_CAL_PWM.c:495:3: warning: #warning "Period control register not available on target device, period will default to 255 + 1"
What is wrong ?
Pwm not work
Re: Pwm not work
Hi Martin. I use chip ATMega 328p (Arduino UNO and Arduino nano). However, as I read in the file CAL_AVR_PWM this chip is not used in it, but only XMEGA and Tiny. Could that be a problem?
- Flowcode1.fcfx
- (10.66 KiB) Downloaded 439 times
- Flowcode1.c
- (28.37 KiB) Downloaded 394 times
- (279.1 KiB) Downloaded 2968 times
mnf
- Has thanked: 70 times
- Been thanked: 440 times
Re: Pwm not work
Timer 0 is an 8 bit timer.
Using Timer1 (choose a different channel) allows alteration and compiles ok. It may be a bug or it may be because Timer 0 is used for delay timing purposes.
Re: Pwm not work
Basically the channel you have selected uses a timer that doesn't support variable periods. Other channels using other timers will work fine.
Nothing wrong just a warning that if you try and change the period using the PWM properties or the ChangePeriod component macro that it won't do anything as the "Period control register not available on target device" and the "period will default to 255 + 1"C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\/AVR\AVR_CAL_PWM.c:110:5: warning: #warning "PWM Channel Uses Resource Timer 0"
What is wrong ?
Re: Pwm not work
Hi Benj. All right, I don't understand why the PWM initially refused to work, may not be the correct parameters set and the warning scared me? Don't know, but now everything works as it should)) Thanks for the help. Have a nice day!
Re: Pwm not work
Hi Martin. All right, may not be the correct parameters set and the warning scared me?)) But now everything works as it should)) Thanks for the help. Have a nice day!
