Same updates reoccurring after download completion.[Fixed]
After selecting full database, the following updates keep appearing after downloading and reloading flowchart:
The components current level are also showing non genuine.Martin
Re: Same updates reoccurring after download completion.
We did create a problem with the RPI targets. We thought we had fixed it but maybe this is just if you didn't download updates while the broken files were available.
You should be able to delete the contents of your "C:\ProgramData\MatrixTSL\FlowcodeV8" folder to effectively start again.
Thank you.
Yes, that has fixed it.Benj wrote:You should be able to delete the contents of your "C:\ProgramData\MatrixTSL\FlowcodeV8" folder to effectively start again.
Thank you.
- STibor
- Has thanked: 116 times
- Been thanked: 113 times
Hello!Benj wrote:Hi Martin,
After deleted C:\ProgramData\MatrixTSL\FlowcodeV8 folder, still remain sticky update files.
Same files as Medelec35.
Same Problem is back for me as well.STibor wrote: After deleted C:\ProgramData\MatrixTSL\FlowcodeV8 folder, still remain sticky update files.
Same files
Deleting
- Has thanked: 1135 times
- Been thanked: 299 times
Hi all!
Is this a bug we have to be aware of or is it fixed, please?
Br. Jorgen
Br. Jorgen
I've had another go and hopefully have now correctly resolved the problem.
