Same updates reoccurring after download completion.[Fixed]
After selecting full database, the following updates keep appearing after downloading and reloading flowchart:
(23.66 KiB) Downloaded 2168 times
The components current level are also showing non genuine.
Re: Same updates reoccurring after download completion.
We did create a problem with the RPI targets. We thought we had fixed it but maybe this is just if you didn't download updates while the broken files were available.
You should be able to delete the contents of your "C:\ProgramData\MatrixTSL\FlowcodeV8" folder to effectively start again.
Benj wrote:You should be able to delete the contents of your "C:\ProgramData\MatrixTSL\FlowcodeV8" folder to effectively start again.
Yes, that has fixed it.
Thank you.
STibor
Has thanked: 116 times
Been thanked: 113 times
Post by STibor »
Benj wrote:Hi Martin,
Hello!
After deleted C:\ProgramData\MatrixTSL\FlowcodeV8 folder, still remain sticky update files.
Same files as Medelec35.
STibor wrote: After deleted C:\ProgramData\MatrixTSL\FlowcodeV8 folder, still remain sticky update files.
Same files
Same Problem is back for me as well.
Deleting
was not a permanent fix. :(
chad
Has thanked: 27 times
Been thanked: 33 times
Post by chad »
I'm Seeing the same thing.
Chad
jgu1
Has thanked: 1135 times
Been thanked: 299 times
Post by jgu1 »
Hi all!
Is this a bug we have to be aware of or is it fixed, please?
Br. Jorgen
I've had another go and hopefully have now correctly resolved the problem.
Confirmed sorted.
Thank you.
chad
Re: Same updates reoccurring after download completion.[Fixed]
Post by chad »
Second conformation. it seems to be fixed for me too.
Chad
