I2C GLCD start problem
Jan Lichtenbelt
Has thanked: 128 times
Been thanked: 264 times
Post by Jan Lichtenbelt »
I'm new in the field of I2C GLCD with SSD1306 driver. I start with showing one number, but I get the error
Test_I2C_LCD_V1.c: 209: (1250) could not find space (128 bytes) for variable _FCV_0cc51_gLCD_SSD1306_i2c1__DRAM0
What to do?
Kind regards
Jan
Test_I2C_LCD_V1.fcfx
(7.98 KiB) Downloaded 657 times
mnf
Has thanked: 70 times
Been thanked: 440 times
Re: I2C GLCD start problem
Post by mnf »
Hi Jan,
Looks like the MCU you are using doesn't have sufficient RAM (1024 bytes on the PIC 16LF1847) for the display buffer.
FC is trying to allocate a buffer of 8 x 128 bytes for the display memory (1k) and there are several other variables (currentX etc) - you could use one of the 32x128 displays instead of the 64 x 128 oLEDs..
Jan Lichtenbelt
Thanks a lot. I will try a microchip with more RAM
Kind regards
Jan
Jan Lichtenbelt
The RAM error has been disappeared using the 16LF18857 microchip.
But now I met an other problem. The address is 0x3C (https://www.okaphone.com/artikel.asp?id=484012) while the flowcode has only the choices between 0x78 and 0x7A. Does someone has a solution for this problem?
Kind regards
Jan
Test_I2C_LCD_V18857.fcfx
(7.92 KiB) Downloaded 338 times
mnf
Post by mnf »
Flow code uses th address shifted left one bit (x2) with bit 0 as r/w
Both systems seem to be in widespread use - but it is a bit confusing - though I think the unshifted form seems more common.
Hi Jan,
Since 0x3C * 2 = 0x78
Then you will will use 0x78 for write and 0x79 to read
viktor_au
Has thanked: 45 times
Been thanked: 63 times
Post by viktor_au »
Hello Jan
ssd1306 default address
The default 7-bit I2C address is = 0x3C or 0b00111100
Which makes the 7-bit address + Write bit = 8bit address or = 0x78 or 0b01111000 (120)
And hence the 7-bit address + Read bit = 8bit address or = 0x79 or 0b01111001
The 8-bit address has one bit to change the mode from the write mode to the read mode.
That is why:
- 0x3C =7bit address
- 0x78 = 8bit address with write mode
-0x79= 8bit address with read mode.
As Ssd1306 allow user to choose the two addresses (you will see the pads on the back of the board), one 8-bit write address would be 0x78 and the other 8-bit read address would be 0x7A.
Normally the program will write to OLED. The 0x78 address is the default one.
Jan Lichtenbelt
Hello Martin(s) and Victor
Thanks a lot for all explanations. Now I have to find out why the display does not work. More research.
Kind regards
Jan
Jan Lichtenbelt
After adding 2 pull-up resistor of 1k8 (with 3V3 power supply), it works!
That made a happy for me.
Kind regards
Jan
Jan Lichtenbelt
I tried to get understanding the results shown on the gLCD:
It seems like the gLCD is not 64x128, but 32x128
I did also a simulation in Flowcode which resulted in:
This looks more as expected for a 64x128 gLCD. Or is there something else what can explain the first picture?
Kind regards
Jan
Hi Jan,
Yes it looks like the resolution of the display is only 32 pixels high assuming you are using font size 0.
Looks like it might be only 32 x 64.
