Hi Matrix,
I have a compiler problem can you please find what the problem is?
The Pic is a 18F46K42
2023: INTCON2bits.INTEDG0 = 1;
^ (192) undefined identifier "INTCON2bits"
^ (196) struct/union required
Radar Velocity.c: FCM_Update_display()
2072: FCV_R_FACTOR = fround(FCV_F_FACTOR, 1);
^ (361) function declared implicit int (warning)
2180: tmr0 = 0x00;
^ (192) undefined identifier "tmr0"
Radar Velocity.c: FCM_int_call()
2220: INTCONbits.PEIE = 1;
^ (192) undefined identifier "INTCONbits"
Radar Velocity.c: main()
2341: INTCON2bits.INTEDG0 = 1;
(908) exit status = 1
Error returned from [xc8.exe]
Thanks,
Wayne Millard
Compile problem
- Has thanked: 7 times
- Been thanked: 12 times
Re: Compile problem
Thanks Wayne,
I'll investigate, please can you attach your program so we can try and replicate.
Re: Compile problem
I've fixed numerous problems with the INT0 and IOC interrupts now on the K42 devices and pushed to the v8 update system.
If you are accessing the TMR0 register using C code then make sure you use the register name in upper case so the compiler can recognise the register.2180: tmr0 = 0x00;
Re: Compile problem
Thanks Benj,
I still have the following problem.
Thanks,
Wayne Millard
Thanks,
Wayne Millard
- Radar Velocity.fcfx
- (33.57 KiB) Downloaded 225 times
Re: Compile problem
Hi Wayne,
The warning should be ok to be ignored and I have now fixed the compilation error for you via the update system.
Re: Compile problem
Sorry Benj,
Thanks for looking into the problems your a star.
There still seems to be a problem.
using updated 32-bit floating-point libraries; improved accuracy might increase code size
Radar Velocity.c: 2414: (2016) interrupt function "myisr" does not service any interrupt sources
Radar Velocity.c: 2072: (1464) number of arguments passed to function "_fround" does not match function's prototype (warning)
Non line specific message: (2020) IRQ 0 (SWINT) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 1 (HLVD) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 2 (OSF) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 3 (CSW) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 4 (NVM) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 5 (SCAN) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 6 (CRC) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 7 (IOC) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 8 (INT0) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 9 (ZCD) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 10 (AD) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 11 (ADT) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 12 (CMP1) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 13 (SMT1) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 14 (SMT1PRA) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 15 (SMT1PRW) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 16 (DMA1SCNT) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 17 (DMA1DCNT) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 18 (DMA1OR) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 19 (DMA1A) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 20 (SPI1RX) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 21 (SPI1TX) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 22 (SPI1) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 23 (I2C1RX) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 24 (I2C1TX) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 25 (I2C1) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 26 (I2C1E) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 27 (U1RX) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 28 (U1TX) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 29 (U1E) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 30 (U1) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 31 (TMR0) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 32 (TMR1) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 33 (TMR1G) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 34 (TMR2) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 35 (CCP1) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 37 (NCO1) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 38 (CWG1) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 39 (CLC1) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 40 (INT1) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 41 (CMP2) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 42 (DMA2SCNT) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 43 (DMA2DCNT) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 44 (DMA2OR) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 45 (DMA2A) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 46 (I2C2RX) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 47 (I2C2TX) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 48 (I2C2) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 49 (I2C2E) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 50 (U2RX) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 51 (U2TX) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 52 (U2E) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 53 (U2) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 54 (TMR3) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 55 (TMR3G) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 56 (TMR4) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 57 (CCP2) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 59 (CWG2) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 60 (CLC2) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 61 (INT2) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 70 (TMR5) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 71 (TMR5G) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 72 (TMR6) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 73 (CCP3) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 74 (CWG3) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 75 (CLC3) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 80 (CCP4) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
Non line specific message: (2020) IRQ 81 (CLC4) in vector table @ 0x8 is unassigned, will be programmed with the address of a RESET instruction (warning)
C:\Program Files (x86)\Flowcode\Compilers\pic\batch\pic_xc8_comp.bat reported error code 1
Wayne Millard
Wayne Millard
Re: Compile problem
Hi Wayne,
Right I've solved the interrupt vector issue now but the fround is still a problem. Investigating this now. Do you need this?
I've pushed the latest definitions so let me know how you get on. I am interested as to if the interrupts are working ok.
Re: Compile problem
Hi Benj,
Thanks for looking at the problem i don't need it to be fixed intel after christmas when i can do the hardware.
Wayne Millard
Wayne Millard
