there must be a problem in the Webserver component: when I use the outgoing replacement strings number %5, %6, %7 the web page freezes or is in error. I am sure of the problem having made numerous tests with elementary web pages; with only outgoing replacement string %0, %1, %2, %4 all working ok.
Problem with Webserver component.
gonzogonzo
- Has thanked: 18 times
- Been thanked: 17 times
gonzogonzo
Re: Problem with Webserver component.
yes of course i increase Outgoing Count in properties; i thinks that problem is this action not work.....
If You work around this is possible also enable more outgoing and incoming replacement string?
gonzogonzo
Hello LeighM,
I send You (PM) a part of test program for this problem (it not work but if You delete %5 %6 it work); for me 12 outgoing and 12 incoming is very good number but if it is possible.
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
The %5 %6 out bug is now fixed and will pushed out on the update system soon.
Please give that a try.
It still has maximum of 12 out and 6 in at the moment.
gonzogonzo
gonzogonzo
Re: Problem with Webserver component (solved)
Hi LeighM,
after last update problem with outgoing string is solved.
Thank again
Thank again
