Problem with Webserver component.
gonzogonzo
Has thanked: 18 times
Been thanked: 17 times
Post by gonzogonzo »
there must be a problem in the Webserver component: when I use the outgoing replacement strings number %5, %6, %7 the web page freezes or is in error. I am sure of the problem having made numerous tests with elementary web pages; with only outgoing replacement string %0, %1, %2, %4 all working ok.
Has thanked: 481 times
Been thanked: 699 times
Re: Problem with Webserver component.
Did you increase the Outgoing Count in the Webserver properties?
gonzogonzo
yes of course i increase Outgoing Count in properties; i thinks that problem is this action not work.....
If You work around this is possible also enable more outgoing and incoming replacement string?
How many do you need?
Also, is it possible to send your program? Send it to me in a PM if you don't want it public.
gonzogonzo
Hello LeighM,
I send You (PM) a part of test program for this problem (it not work but if You delete %5 %6 it work); for me 12 outgoing and 12 incoming is very good number but if it is possible.
The %5 %6 out bug is now fixed and will pushed out on the update system soon.
Please give that a try.
It still has maximum of 12 out and 6 in at the moment.
gonzogonzo
next week i test again and report news.
gonzogonzo
Re: Problem with Webserver component (solved)
Hi LeighM,
after last update problem with outgoing string is solved.
Thank again
