Division by 10 easy?
Jan Lichtenbelt
Has thanked: 128 times
Been thanked: 264 times
Post by Jan Lichtenbelt »
I have a simple counter from 1 to 20. But I need the counter diviede by 10. Counter is A_byte and the 10th part is A_real. The simulation works correctly. But the microchip has different ideas about this 'problem'. All numbers are correct, except A_byte=14 and A_real should be 1.4. The reality is, see picture
How is this possible?
Test_Counter_V1.fcfx
(9.13 KiB) Downloaded 260 times
Kind regards
Jan
Jan Lichtenbelt
Re: Division by 10 easy?
In the meanwhile I found the solution. All real numbers have positive rounding errors, while 1.4 has been calculated with an negative error with results 1.399...... The 3 lift characters will result into 1.3 instead of 1.4
Kind regards
Jan
Has thanked: 114 times
Been thanked: 422 times
Post by Steve »
Hi Jan,
If you just want to display the divided number rather than do any maths on it, then you could do something like this:
1) convert the integer to a string:
value_as_string = ToString$(my_int_value)
2) display the first part of the string:
Left$(value_as_string, Length$(value_as_string)-1)
3) display a "."
4) display the last digit:
Right$(value_as_string, 1)
Steve.
AbhijitR
Has thanked: 284 times
Been thanked: 80 times
Post by AbhijitR »
Hello! Jan
Many thanks for this post, some what life saving for me.
Jan Lichtenbelt wrote:In the meanwhile I found the solution. All real numbers have positive rounding errors, while 1.4 has been calculated with an negative error with results 1.399...... The 3 lift characters will result into 1.3 instead of 1.4
Any idea how to round off the answer 12.3 to 12 and 12.6 to 13, I think to round off to the nearest value before and after 0.5
Thank you again.
Abhi
AbhijitR wrote: Any idea how to round off the answer 12.3 to 12 and 12.6 to 13, I think to round off to the nearest value before and after 0.5
Hi Abhi,
I believe the round() function will do what you are after.
If you open a calculation box, then select fx, you can scroll down to round().
AbhijitR
Post by AbhijitR »
Hi! Martin
medelec35 wrote: If you open a calculation box, then select fx, you can scroll down to round().
No exaggeration, you are more or less WIKI for FC, thank you once again for that quick reply.
Abhi
