ADC - error during compile.
Devices affected are:
18F2220, 18F2221, 18F2320, 18F2321, 18F24J10, 18F2410, 18F2420, 18F2423, 18F2450,
18F2455, 18F2480, 18F25J10, 18F2510, 18F2515, 18F2520, 18F2523, 18F2525, 18F2550,
18F2580, 18F2585, 18F2610, 18F2620, 18F2680, 18F4220, 18F4221, 18F4320, 18F4321,
18F44J10, 18F4410, 18F4420, 18F4423, 18F4450, 18F4455, 18F4480, 18F45J10, 18F4510,
18F4515, 18F4520, 18F4523, 18F4525, 18F4550, 18F4580, 18F4585, 18F4610, 18F4620,
18F4680, 18F4682 & 18F4685.
Jonny was the first to post about this:
http://www.matrixmultimedia.com/mmforum ... 452#p31445
Unfortunately I did not see that post when I posted my fix here:
http://www.matrixmultimedia.com/mmforum ... 077#p31579
Fix still worked OK, but not sure if 12 Bit ADC devices will work?
STibor
Has thanked: 116 times
Been thanked: 113 times
Re: ADC - error during compile.
Post by STibor »
Pic18f6622 external ADC Vref setting does not work.
I checked the Flowcode4 PIC_ADC_12.c file included in the following line:
/ / assign VREF Functionality
 # if (MX_ADC_VREF_OPT! = 0)
 st_bit (adcon1, VCFG0);
 # endif
Flowcode5 PIC_CAL_ADC.c line in the following file:
// ADC Type 12 Supported Devices
Now...
 if (Vref! = 0) / / assign VREF Functionality
 st_bit (adcon0, VCFG0);
Change to...
 Rewriting: if (Vref! = 0) / / assign VREF Functionality
Simulator works, not tested circuit.
PIC_CAL_ADC.c
(85.83 KiB) Downloaded 369 times
Enamul
Has thanked: 271 times
Been thanked: 814 times
Post by Enamul »
Yes. You are right as datasheet says the same..This snapshot from ADCON1 register not from ADCON0.
(8.73 KiB) Downloaded 2371 times
Thanks for letting us know.
Enamul
University of Nottingham
enamul4mm@gmail.com
