Breakpoint in component halts FC on comp. macro call
Please add any bug reports that require discussion here
Forum rules
Only bug reports will be considered here. General questions should not be posted in this forum.
kersing
Has thanked: 553 times
Been thanked: 1081 times
Post by kersing »
When a component macro contains a breakpoint any flowchart using the component will pause simulation on that component macro call as if there was a breakpoint set in the flowchart itself. The source of the component is required to remove/disable the breakpoint.
As the component macro itself can not be single stepped this 'feature' does not add value (imho).
― C.S. Lewis
JonnyW
Has thanked: 63 times
Been thanked: 290 times
Re: Breakpoint in component halts FC on comp. macro call
Post by JonnyW »
I was hoping no-one would notice.
This will be sorted in the next release.
Jonny
