Hello everyone
Can I make PWM ouput directly from MIAC Arduino
Type: MI5466 AVR ATmega1281
How can PWM ouput made?
Like a small code eksemple!
The example below does not work in MIAC Arduino.
Attached:
- Has thanked: 17 times
- Been thanked: 46 times
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Re: PWM ouput directly from MIAC Arduino
Hi Monie
Motor 1 (PB7) is an enable signal for outputs A and B
So you also need to set A and/or B.
So just add for example OutputON(1)
Hope that helps,
Leigh
Hope that helps,
Leigh
- MIAC PWM TEST.fcfx
- (7.74 KiB) Downloaded 416 times
HI LeighM
On the oscilloscope I can not see anything PWM ouput A or B
I use your example!
User Flowcode v7
I use your example!
User Flowcode v7
Best Regard
Monie
Monie
- LeighM
Hi Monie,
That is very strange.
Could you post your generated C file "MIAC PWM TEST.c" and I will see if there are any differences with mine.
If you just have a loop with a delay and OutputON(1) delay OutputOFF(1)
and no PWM, does that give an output?
Also could you check the PWM component has a valid prescaler setting on your project.
Leigh
Leigh
HI LeighM
Hendes ER C-fil "MIAC PWM TEST.c".
Attached:
Attached:
Best Regard
Monie
Monie
- LeighM
Hi Monie,
I think the issue is that the default prescaler value for the PWM component is not valid for the ATmega device.
So you need to change it with the drop down list.
Hope that helps,
Leigh
Hope that helps,
Leigh
HI Leigh
OK with the "default prescaler".
I write prescaler manual.
Thank you very much.
GO'Weekend
GO'Weekend
Best Regard
Monie
Monie
