error code -1
saschech@gmx.de
Has thanked: 1 time
Been thanked: 26 times
error code -1
Post by saschech@gmx.de »
I have probleme to compile.
Change short and long name no succsess
Any ideas
Regards wolfgang
error code.GIF (116.93 KiB) Viewed 13635 times
Has thanked: 481 times
Been thanked: 699 times
Re: error code -1
What version of Flowcode are you running? (Menu Help->About Flowcode)
Could you look in your Flowcode7 installation directory, in \compilers\STARM\batch and see if you have the file F429Disco.bat
saschech@gmx.de
Has thanked: 1 time
Re: error code -1
hello
Re: error code -1
If you change the target to another ST ARM, such as 32F405RE, does that compile OK?
saschech@gmx.de
Has thanked: 1 time
Re: error code -1
hello
The same
Re: error code -1
Since installation, has Flowcode compiled anything?
Do other targets such as PIC 16F1937 compile?
saschech@gmx.de
Has thanked: 1 time
Re: error code -1
hi LeighM
I install on my laptop v7 also and have the same problems to compile the arm-projekts.
with the pic no problem.
Regards wolfgang
compile ok.GIF (172.07 KiB) Viewed 13617 times
Re: error code -1
Strange.
Does an AVR target compile, e.g. Arduino Uno?
This FAQ might help ...
http://www.flowcode.co.uk/faq/index.php? ... artlang=en
saschech@gmx.de
Has thanked: 1 time
Re: error code -1
After new install with eneable 8.3 compiler is ok,but I have a new error
Regards Wolfgang
new error F746.GIF (124.54 KiB) Viewed 13607 times
Re: error code -1
that's good then :D
could you attach your Flowcode project file? (.fcfx)
thanks
saschech@gmx.de
Has thanked: 1 time
Re: error code -1
hi
no problem
Versuch001.rar
(292.29 KiB) Downloaded 373 times
Re: error code -1
The gLCD has to match the target device.
You cannot use the 429 gLCD with 746 device.
Have a scroll through the gLCD components and you will see the correct display for whichever Discovery board target you want to use
saschech@gmx.de
Has thanked: 1 time
Re: error code -1
After do all new,show all ok on the display.
Thank you
