Hello!
Any change HX8347D is going to be supported by flowcode?
Thank you
HX8347D display controller
headhuntergr
- Has thanked: 34 times
- Been thanked: 5 times
headhuntergr
Re: HX8347D display controller
I will add it to the list to investigate.
Have you seen this topic on creating your own graphical display components, if you fancy a go then it could either allow you to make your own component or at least save us some time when we have a look.
viewtopic.php?f=66&t=19116
And another example component here with source.
viewtopic.php?f=66&t=19147
If the component needs to use a CAL (SPI or I2C) then you can find information on doing that here.
https://www.flowcode.co.uk/wiki/index.ph ... Components
