Flow 8
electron67
Has thanked: 106 times
Been thanked: 48 times
Flow 8
Post by electron67 »
I see that Flow 8 is ready, could you give any advance of the new components that will be included :?:
Enrique
Re: Flow 8
Most of the new features are discussed here:
viewtopic.php?f=8&t=20075
As for specific components, all will be revealed on Wednesday...
Has thanked: 1135 times
Been thanked: 299 times
Re: Flow 8
Post by jgu1 »
Hi Steve!
Is it also possible to import project`s from FC7 FC6 FC5 ect. Without problem, and include C code?
I have now FC7 proff. When I upgrade to FC8, do I still have the same chippack and other feature as I have bougth in FC7 and is it possible to add RPI?
Please.
Br Jorgen
Re: Flow 8
When you upgrade, you should get 50% off most of the chip and feature packs. If you don't have the equivalent licence for a pack in v7, then I think you'll need to pay full price for that particular pack.
Re: Flow 8
Post by jgu1 »
Hi MM!
Just try to buy, upgrade FC8, or get the price for my wish, but no succes.
First, what is the toolchain, is this something I have to buy also?
Can´t find :
Once the 'Get Key' button you will be taken the checkout to purchase your Flowcode key. Where is this ?
Everytime I look in basket, the QTY is added up with one more.?
How do I get the discount code?
Sorry, but I am a bit confused :o
Jorgen
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Re: Flow 8
Post by QMESAR »
Jorgen.
jgu1 wrote:First, what is the toolchain, is this something I have to buy also?
No the tool chain is the compiler which was previous included in the Flowcode installation now you have to down load the compiler"Toolchain" desperately and install it ,you down load the once you use for example you use AVR then you down load the AVR Tool chain and not the otter ones.
Go to Flowcode >> download and at the bottom of the page you will see it
jgu1 wrote:Once the 'Get Key' button you will be taken the checkout to purchase your Flowcode key. Where is this ?
Jurgen go to buy Flowcode select Upgrade and the login to your account and then select the packs you want you will see the discount they are shown on each pack then when you buy you get the key per email and instruction how to add it to your Matrix account
I hope this helps :D
Re: Flow 8
Post by jgu1 »
Hi QMSAR!
Thank you for help. :D
But doesn´t help. I get no email. In my opinion, I think it is a Little tricky to upgrate. And concerning "toolchain" (who could know we need that)I could imagine I have to download and run for every chippack I choose? It would be nice with a " ho to do" from MM. You know step one, step two, ect.
Keep on FC7, it work´s :wink:
Thank´s QMSAR,
Br. Jorgen
mnf
Has thanked: 70 times
Been thanked: 440 times
Re: Flow 8
Post by mnf »
I found a quirk with installing the toolchain...
Installing to it's default directory (of program files (x86)) - causes compilation to fail with
Launching the compiler...
E:\Program Files (x86)\Flowcode\Common\Compilers\avr\batchfiles\avra.bat atmega328p "C:\Users\Martin\DOWNLO~1\test8.elf" "C:\Users\Martin\DOWNLO~1\test8.c" "C:\Users\Martin\DOWNLO~1\test8.lst"
'E:\Program' is not recognized as an internal or external command,
operable program or batch file.
- Seems not to like the spaces in the file path.
Install to a directory such as c:\Flowcode\toolchain\.. instead to avoid this.
DanielM
Has thanked: 11 times
Been thanked: 22 times
Re: Flow 8
Post by DanielM »
mnf wrote:I found a quirk with installing the toolchain...
Hi Martin,
I investigated, and it does not seem to be necessarily the presence of spaces. There appears to be a bug where certain paths that aren't on the C:\ drive aren't invoked correctly. E.g. "C:\Program Files (x86)" is ok, but "E:\Program Files (x86)" is not. "E:\ProgramFIles" is ok also, but not "E:\ProgramFiles(x86)" (even though there are no spaces). All paths on C:\ appear to work in my tests so far though, so you shouldn't encounter any problems as long as the toolchain is on that partition.
I will do some more investigating,
Thanks,
Daniel
EDIT: Any paths on D:\ partitions also appear to be fine.
mnf
Re: Flow 8
Post by mnf »
Thanks, I'd installed Flowcode 8 (and the AVR toolchain) onto drive E:.
Reinstalling to E:\Flowcode had fixed the problem - but I didn't try the C: drive (I have Flowcode 7 installed and wanted to keep 8 seperate)
Re: Flow 8
Hi Martin,
We're still looking into this. Can you please do me a favour - can you check to see if your E: drive is producing legacy 8.3 filenames? You will not need to reinstall Flowcode or the toolchains, so it should be a quick check.
To do this, open a command prompt and type:
dir /X e:\
Within this, you should see something like this:
(3.41 KiB) Downloaded 3016 times
If the "PROGRA~2" is missing then that could be the source of the problem and we should be able to provide a fix or workaround.
Thanks,
Steve.
Re: Flow 8
We have confirmed this and it does seem to be an issue with 8.3 short names being missing.
The generation of short names is sometimes turned off by 3rd-party optimisers, even though the time saving in practice is negligible. It can be turned back on via these instructions:
http://omtool.com/documentation/HPCR/v1 ... eation.htm
This fix involves editing the registry and so I recommend you make this change only if you are comfortable editing it and understand the consequences if the wrong things get changed.
For anyone who is not comfortable with editing the registry, I suggest you use the workaround of installing the compiler toolchains into a location such as "C:\Flowcode\Toolchains" as suggested by Martin above.
Re: Flow 8
Further to Steve's post you probably also need to follow the steps in this FAQ.
http://www.flowcode.co.uk/faq/index.php? ... artlang=en
mnf
Re: Flow 8
Post by mnf »
Thanks for the pointers - I do seem to have the short names options turned off (only on drive E:) (though no optimizer software running - it's usually disappointing!) Strangely regedit refuses to run since the last windows 10 update.... Another great step forward from MS.
