I have problem with SPI. Maybe mistake is my, maybe it's a bug.
I want produced DAC volt and DAC current with MCP4922. It's a 2 channel SPI DAC from Microchip.
But I found something strange.
Vol toutput is 2,5V and Current output is 0V with dac_Volt and dac_Current = 0.
With dac_Current I can adjust only Volt Output.
If I decrease dac_Current by one, output Volt is jump to 5V. If increase dac_Current, output is increase too.
With dac_Volt can't adjust anything.
I connect PIC MOSI with MOSI on MCP4922. Otherwise I lost comunication. And should not I connect MISO with MOSI and vice versa? Same problem with connection exist and with MCP3202.
This is real design.
I post Flowcode project, datasheet MCP4922 and Proteus project.
(Solved) Atmega16_MCP4922 problem
maharadga
- Has thanked: 17 times
- Been thanked: 12 times
- MCP4922.pdf
- (3.62 MiB) Downloaded 276 times
- Proteus_Atmega16_MCP4922.rar
- (17.49 KiB) Downloaded 294 times
- Atmega_16_MCP4922.fcfx
- (22.67 KiB) Downloaded 286 times
Re: Atmega16_MCP4922 problem
MOSI = Master Out (SDO) Slave In (SDI)
MISO = Master In (SDI) Slave Out (SDO)
So the cross connection is done for you using the MOSI / MISO naming convention.
Looks like you are very close to a solution. This line of code may be the problem.
Try adding brackets to ensure the maths is correct.
Same for the Current channel.
Let us know how you get on.
MOSI should go to MOSI and MISO should go to MISO.I connect PIC MOSI with MOSI on MCP4922.
send_Volt = dac_Volt | 0x7 << 12Code: Select all
send_Volt = dac_Volt | (0x7 << 12)Let us know how you get on.
Have you wired up the external Latch pin and Enable pin?
maharadga
I changed in Properties "Clock polarity" to Idle High and problem was resolved.
This work in real chip.
Have a nice day.
Have a nice day.
- (20.34 KiB) Downloaded 301 times
