Sir
I am installing flowcode 8 in my computer with Windows XP. After install flowcode8, the application is not run...showing its not a valid win 32 application..
Is the flowcode 8 is 64bit system?
which version of flowcode support 32 bit windows system and 8 bit microcontroller like 12F675...?
Manoj Soorya
Flowcode is not valid win32 application
manoj soorya
- Has thanked: 4 times
manoj soorya
Re: Flowcode is not valid win32 application
Thank you medelec35 for the fast reply.....also remembering the requirement of the minimum system facilities...
I just post another thread about 12F675.
Hope you will help me
Regards Manoj
Regards Manoj
Your welcome.
Flowcode v6 looks like it will work with Windows xp
I don't know if its even possible to purchase via sales as I don't work for Matrix TSL
It maybe worth asking the question?
Explain you only run windows XP so only Flowcode v6 and below will work.
You won't have as many target devices as V8 so its worth getting V8 as soon as your windows is upgraded.
I don't want to give you false hope as the decision could go either way.
EtsDriver
- Has thanked: 345 times
- Been thanked: 227 times
Id recommend you to upgrade your PC, as cheap laptop with windows 10 could run flowcode 8 without problem. It is not worth the hassle to use XP anymore for anything, as it has been unsupported by Microsoft for about ten years allready.
https://support.microsoft.com/en-us/lif ... earch/1173
I agree with EtsDriver!
That will be a better way to go.
