PWM Icon red not yellow
beneee
Has thanked: 6 times
Post by beneee »
Hi All,
I have a simple program which I could not get to run on the chip, simulation was fine, I re-wrote it again with identical settings and it worked, what did I do wrong in the non-working one (Nwork) and why was the PWM image red instead of yellow?
Ben
NWork.fcfx
(8.7 KiB) Downloaded 173 times
YWork.fcfx
(8.75 KiB) Downloaded 168 times
Re: PWM Icon red not yellow
The difference is the configuration settings in the project options. YWorks is set to use the INTOSC and NWorks is set to use an external clock.
I would also disable the watchdog timer and Low Voltage Programming options.
beneee
Post by beneee »
Ahh, awesome, great work - thanks Benj
Ben
