V4.5 PIC 18F8490 and CAN Component
beambase
Has thanked: 6 times
Been thanked: 8 times
Post by beambase »
I have a problem with a project that was origibaly done in V4.3 but after upgrading to V4.5 it will not complie correctly.. The PIC used is 18F8490 and the hardware is the external CAN controller MCP2515.
No CAN signal at all can be detected when copiled from V4.5. But when using a HEX file generated on a computer running 4.3 the CAN signal is fine.
Any ideas on how to fix this. I need to get this going tonight...... so please help.
Re: V4.5 PIC 18F8490 and CAN Component
Hm that's strange. Please can you post up the Flowcode file and the generated C file. Also if you have the C file from the v4.3 compilation then that would also be handy If you don't have this then no problems. I will have a look through the component code and see what has changed between revisions.
beambase
Post by beambase »
I have PMed you the files since they are commercial. Hope it workes anyway.
Thanks for the files.
Here is a copy of the v4.3 CAN component C code. You should be able to replace the file in your "Flowcode v4/components" directory with the attached file, restart Flowcode and you should be up and running again. I will have a dig in and see why the newer file is causing problems. Cheers for all your PM files they should make the task a lot simpler.
PIC_CAN.c
(42.64 KiB) Downloaded 284 times
Let me know how you get on with the component C code.
beambase
Post by beambase »
I am not able to create a hex file. I am getting the following error
Can2test8490.c
Starting preprocessor: c:\PROGRA~2\MATRIX~1\FLOWCO~1\boostc\pp.exe Can2test8490.c -i c:\PROGRA~2\MATRIX~1\FLOWCO~1\boostc\include -d _PIC18F8490 -la -c2 -o Can2test8490.pp -v -d _BOOSTC -d _PIC18 -d _CHAR_INDEX
Can2test8490.c(452): Illegal redefinition of symbol: TX1IE
Can2test8490.c(453): Illegal redefinition of symbol: TX2IE
Can2test8490.c(462): Illegal redefinition of symbol: TX1IF
Can2test8490.c(463): Illegal redefinition of symbol: TX2IF
Any Ideas?
beambase
Post by beambase »
Hello Again...
is there a link somewhere to V4.3 so I can re-install the olde version again?
I am really pressed for time to get this working. Sitting i a on site in a hotelroom and needs to get this done by tomorrow morning.....
Sorry about this here is a link to the v4.3 installer.
http://www.matrixmultimedia.com/softwar ... codeV4.exe
You will first have to uninstall v4.5 before 4.3 will allow you to install it correctly.
DavidA
Has thanked: 58 times
Been thanked: 258 times
Post by DavidA »
I will add to this,
In case you did not know, you will not need to enter licence details again, just defer the entering of licence information and it should still remain fully registered to you.
beambase
Post by beambase »
there seams to be a different PIC_CAN.c file on my working system.
In comments it has the following line:
* 231109 | SK | Commented out definitions of TX1IE, TX2IE, TX1IF, TX2IF. Clash with definitions for some PIC devices (18F8490).
File is attached.
But this file does not work in a V4.5 installation.
Could you make a V4.5 compatible version of this file and send it to me?
PIC_CAN.c
Working file
(39.2 KiB) Downloaded 270 times
beambase
Post by beambase »
Have you had any time to look at this? When can I get a working PIC_CAN.c file for 18f8490 and V4.5?
DavidA
Post by DavidA »
Hello beambase,
We are currently looking into why this might not be working.
Here is a slightly modded version of the v4.5 CAN component C file. Please can you give this a go and let us know how you get on.
PIC_CAN.c
(42.61 KiB) Downloaded 242 times
beambase
Post by beambase »
this time I get these errors
Error: .obj or .lib file Incompatible version! (file uses V111, linker requires V113 to V113)
Error: Failed to process:libc.pic18.lib
Error: .obj or .lib file Incompatible version! (file uses V109, linker requires V113 to V113)
Error: Failed to process:flowcode.pic18.lib
Error: Failed to process:rand.pic18.lib
Error: Failed to process:float.pic18.lib
failure
Return code = -2
Any ideas?
Have you modified the boostc directory at all. It looks like the incorrect linker is being used which is causing the errors. May be worth uninstalling, deleting the Flowcode v4 folder to ensure no left over files remain and then re-installing if you have not modified the folder.
beambase
Post by beambase »
Yes,
fresh install made it work.
Thank you!
That's great news, Thanks for letting me know.
