Disabling Icons
Revision as of 08:56, 16 August 2013 by ReeceL (talk | contribs)
<sidebar>Sidebar: Taking Flowcode Further</sidebar>
You can now disable any icons in a flowchart. Disabled icons will be ignored by the simulation and compiler. A disabled icon is greyed out to signify it has been disabled.
Disabling a 'parent' icon will also disable any icons that follow directly from that icon. For example, disabling a 'Switch' icon will disable all icons within the Switch statement, and disabling a 'Loop' icon will also disable all the icons in the loop.
To disable icons, select the icon or icons you wish to disable, right-click on them and select "Disable Icon" from the context menu.
By using this feature the user can quickly and easily test flowcharts and ideas to improve the program, and then quickly revert the changes if the changes are not as effective.
