Exercise - Using Simulation Macros
Revision as of 11:32, 24 August 2013 by JohnVerrill (talk | contribs)
Even a cursory glance at the dialogue box used to configure them shows that they are very powerful devices, with a huge range of possible effects.
This exercise uses two of them to illustrate the use of a PIR (passive infra-red sensor) to operate an intruder sensor.
The physical background
The scene depicts the front of a house. A PIR sensor is mounted on the wall of the house, above the path leading across the garden. The data sheet for the PIR shows that it is sensitive to a range of 10 metres, within a cone of angle 100 degrees.
On the System Panel, create:
  • a brick wall, represented by adding a red cuboid and changing it to a rectangle, 15mm wide, 120mm high and 120mm deep,
located at coordinates x = 10, y = 0, z = 60,
with rotation settings X = 0, Y = 0, Z = 180;
  • a path, represented by a grey rectangle, 240mm wide, 100mm high and 0mm deep,
located at coordinatesx = 140mm, y = 0mm, z = 0mm,
with rotation settings of X = -180, Y = 0, Z = -180;
  • a cone, couloured light blue, representing the sensing region of the PIR, with width = 70mm, height = 250mm, depth 95mm,
located at coordinates x = 55mm, y = 0mm, z = 80mm,
with rotation settings of X = 0, Y = 55, Z = 180.
  • Drag the mouse cursor over these three elements and group them together. This produces 'group 1'.
Give it:
dimensions - width = 265mm, height = 250mm, depth = 135mm;
coordinates - x = 128, y = 0, z = 68;
rotation - X = 90, Y = 0, Z = 0.
Also on the System Panel, create an intruder, by:
  • adding four spheres, and configuruing the properties as follows:
sphere 1 (the head):
dimensions - width = 12mm, height = 13mm, depth = 15mm;
coordinates - x = -2.2, y = 0.7, z = 22;
sphere 2 (the body):
dimensions - width = 14mm, height = 26mm, depth = 24mm;
coordinates - x = -2.2, y = 0.5, z = 4;
rotation - X = 90, Y = 0, Z = -180.
sphere 3 (the legs):
dimensions - width = 9mm, height = 23mm, depth = 15mm;
coordinates - x = -2.2, y = 1, z = -16;
sphere 4 (the feet):
dimensions - width = 18mm, height = 32mm, depth = 60mm;
coordinates - x = 1.5, y = 0, z = -25;
rotation - X = 90, Y = 90, Z = 0.
  • Drag the mouse cursor over the four spheres and group them together.This produces 'group 2'.
Give it:
coordinates - x = 165, y = 0, z = 28;
The System Panel should resemble the image shown opposite:
  • Flowcode
  • Experienced
  • Students
Adding supplementary code
This feature
Definitions and function declarations:
This is
Function implementations:
