API File.Create
<sidebar>API contents</sidebar> Creates the new file as a standard stream
Class hierarchy
- File
- Create
STRING Filename
- A textual filename to create
BOOL Read
- Set to enable read access
BOOL Monitor
- Set to enable monitoring of the file
- Add to a calculation icon:
result = ::File.Create("filename", true, false)
