API Scope.FindBaud
Revision as of 15:57, 16 January 2014 by JonnyW (talk | contribs) (XML import)
<sidebar>API Contents</sidebar> Attempts to calculate the baud given a series of transitions for the stream, returns calculated baud
Class hierarchy
Scope
FindBaud
HANDLE StreamH
The stream that is to be read
LONG TimeUS
The time offset to start the calculation from, in microseconds
ULONG SearchMax
The maximum number of microseconds to scan, +ve only
ULONG MinBaud
A minimum value to consider for the baud
The default value for this parameter is: 1
ULONG MaxBaud
A maximum value to consider for the baud
The default value for this parameter is: -1
ULONG
Returns calculated baud
  • Declare a variable 'result' of type ULONG
  • Add to a calculation icon:
    result = ::Scope.FindBaud(streamh, timeus, searchmax, minbaud, maxbaud)
