Component: GSM (EB066, Generic AT) (Wireless)
Revision as of 15:58, 16 January 2014 by JonnyW (talk | contribs) (XML import)
Author Matrix Ltd.
Version 1.2
Category Wireless
Image GSM (EB066, Generic AT) component
Low level routines for controlling a standard AT GSM / GPRS interface Also available in the form of the EB066 GSM E-block.
DialNumber
Performs a standard voice call by dialling the number specified.
Returns 0 for call in progress and 255 for no response.
<- STRING Number
This parameter may be returned back to the caller
BYTE
GetTextString
BYTE NumBytes
STRING
SendScript
Send an AT command script.
Returns 0 for fail, 1 for success and 255 for unrecognised script idx.
BYTE idx
BYTE
AnswerIncomingCall
Answers the phone for an incoming type call.
Returns 0 for success and 255 for failure.
This macro has no parameters
BYTE
SendCommand
Sends a command string to the GSM module.
0 = Command sent ok, 255 = No Reply
<- STRING Command
BYTE SendCR
BYTE
GetTextNumber
BYTE NumBytes
STRING
HangUpCall
Ends a voice based call.
BYTE
ReadString
Copies the data from the data string array to a local string variable
BYTE NumBytes
STRING
SendTextMessage
Sends the text message data specified to the number specified using the SMS protocol.
<- STRING Number
<- STRING Message
BYTE
StringReceive
BYTE
CheckNetworkStatus
Returns the state of the GSM network.
0 = Not connected, 1 = connected, 255 = no reply from GSM.
BYTE
CheckForIncoming
Checks to see if any incoming phone call or SMS message.
0 = Nothing, 1 = Text Received, 2 = Phone Ringing
BYTE
Sets up the GSM module.
Returns 0 for OK, 255 for no reply and 254 for command fail.
BYTE
Simulation macro reference
Expect Echo
This property is of type True or false and can be referenced with the variable name expect_echo.
String Array Size
This property is of type Signed integer and can be referenced with the variable name string_size.
Amount of RAM memory to dedicate to receiving responces from the GSM
Message Array Size
This property is of type Signed integer and can be referenced with the variable name message_size.
Amount of RAM memory to dedicate to storing the last SMS message received by the GSM.
This property is of type Fixed list of ints and can be referenced with the variable name baud.
Flow Control
This property is of type True or false and can be referenced with the variable name flow_control.
Script Count
This property is of type Fixed list of ints and can be referenced with the variable name script_count.
Script1
This property is of type Multiple lines of text and can be referenced with the variable name script1.
This property is of type Fixed list of ints and can be referenced with the variable name channel.
TX Pin
This property is of type Single digital pin and can be referenced with the variable name tx_pin.
RX Pin
This property is of type Single digital pin and can be referenced with the variable name rx_pin.
