API Panel.Position.Camera.SetTarget
Revision as of 14:58, 11 May 2016 by BenR (talk | contribs)
<sidebar>API Contents</sidebar> Sets the target point of the camera
Class hierarchy
Panel
Position
Camera
SetTarget
HANDLE Target
The target position to look at
BOOL UseAxis
True to apply the axis to the eye, else just use the coordinates
BOOL Animate
True to animate movement from the current position
This sets the position of the target whilst maintaining the position of the eye point. The Target is used to set the coordinates, and if UseAxis is true, to establish an up-vector for orientation (which affects the roll around the vector from the eye to the target). If UseAxis is false then the current eye to target vector is used to calculate orientation. Scale is ignored.
  • Add to a calculation icon:
    ::Panel.Position.Camera.SetTarget(target, true, false)
SetTarget
Simple example to focus the system panel camera on objects on the panel.
CameraSetTarget
