API File.AbsPath
Revision as of 21:24, 11 May 2013 by Admin (talk | contribs) (XML import)
<sidebar>API contents</sidebar> Gets an absolute path from a relative filename
===Class hierarchy===File
AbsPath
STRING Filename
The path of the file relative to the project file
HANDLE Owner
A component that owns the file if it is a resource
STRING
  • Declare a variable 'result' of type STRING
  • Add to a calculation icon:
    result = ::File.AbsPath("filename", owner)
