Component: Modbus Slave (Comms: System)
| Author | Matrix Ltd. |
| Version | 1.2 (Release) |
| Category | Comms: System |
Modbus component for creating Modbus compatible slave hardware via RS232 or RS485.
ReadHoldingRegister
Reads the value of a single holding register.
- UINT Address
- Coil Address
ReadCoilStates
Reads the state of a single digital coil.
Can pack a max of 8-bits together in a single operation
- UINT StartAddress
- Coil Address Range 0 to (NumCoils - 1)
- BYTE AddressCount
- Range 1-8
ReadAnalogueInput
Reads the value of a single analogue input.
- UINT Address
- Coil Address
ReadInputStates
Reads the state of a single digital input.
- UINT StartAddress
- BYTE AddressCount
- Range 1-8
SetSlaveAddress
Allows the slave address to be overridden from the default slave address specified
in the component property. The number of bytes used for the address is fixed by the
Slave ID Bytes property to save on RAM usage.
- UINT SlaveAddress
SetCoilState
Sets the state of a single digital coil.
- UINT Address
- Coil Address
- BYTE State
- 0=off, 1=on
SetInputState
Sets the state of a single digital input.
- UINT Address
- Coil Address
- BYTE State
- 0=off, 1=on
SetBaudRate
Allows the Baud Rate to be controlled dynamically overriding the default
rate specified by the Baud component property.
- BYTE Rate
- 0=1200, 1=2400, 2=4800, 3=9600, 4=19200, 5=38400, 6=57600, 7=115200
SetHoldingRegister
Sets the state of a single holding register.
- UINT Address
- Coil Address
- UINT Value
- Analogue Value range 0 - 65535
CheckForIncoming
Checks for an incoming message and if the data address is within range then also automatically replies with the correct reply.
Returns 0 if no comms received, 1 for a succesful transaction, 255 for an error.
SetAnalogueInput
Sets the state of a single analogue input.
- UINT Address
- Coil Address
- UINT Value
Starts up the UART to allow communications and initialises the states of the various
Modbus Coils, Inputs and Registers to 0.
Simulation macro reference
This property is of type Fixed list of ints and can be referenced with the variable name CHANNEL.
UART channel to specify an onboard hardware channel.
Software channels are not availlable as we rely on hardware UART RX interrupts to pull in the data
TX
This property is of type Single digital pin and can be referenced with the variable name TX.
UART transmit pin
RX
This property is of type Single digital pin and can be referenced with the variable name RX.
UART receive pin
This property is of type Fixed list of ints and can be referenced with the variable name BAUD_LIST.
Data rate in bits per second
Bus
This property is of type Fixed list of ints and can be referenced with the variable name BusType.
Specifies the bus mode being used,
RS232 allows you to connect a single master node to a single slave node.
RS485 allows you to connect a single master node to multiple slave nodes.
Timeout
This property is of type Unsigned integer and can be referenced with the variable name Timeout.
Timeout in milliseconds used to dictate the maximum time to wait in milliseconds between bytes in a packet.
Range: 1 - 255
Frame Type
This property is of type Fixed list of ints and can be referenced with the variable name FrameType.
Switches between RTU and ASCII forms of Modbus
Receive Buffer Size
This property is of type Unsigned integer and can be referenced with the variable name ReceiveBufferSize.
Slave ID Bytes
This property is of type Unsigned integer and can be referenced with the variable name AddressBytes.
Slave Address
This property is of type Unsigned integer and can be referenced with the variable name SlaveAddress.
Data Source
This property is of type Fixed list of ints and can be referenced with the variable name DataSource.
Simulation data source used to allow the component to connect to COM port hardware or the the data injector components.
COM Port
This property is of type Fixed list of ints and can be referenced with the variable name COM_port.
COM port assigned to allow the simulation to communicate with actual Modbus hardware.
Starting Address
This property is of type Unsigned integer and can be referenced with the variable name StartAdrCoil.
Number of Addresses
This property is of type Unsigned integer and can be referenced with the variable name NumAdrCoil.
Specifies how many Coils are available on the slave. Max 80 coils.
Starting Address
This property is of type Unsigned integer and can be referenced with the variable name StartAdrDI.
Number of Addresses
This property is of type Unsigned integer and can be referenced with the variable name NumAdrDI.
Specifies how many Digital Inputs are available on the slave. Max 80.
Starting Address
This property is of type Unsigned integer and can be referenced with the variable name StartAdrAI.
Number of Addresses
This property is of type Unsigned integer and can be referenced with the variable name NumAdrAI.
Specifies how many 16-bit analogue inputs are available on the slave. Max 10.
Starting Address
This property is of type Unsigned integer and can be referenced with the variable name StartAdrReg.
Number of Addresses
This property is of type Unsigned integer and can be referenced with the variable name NumAdrReg.
