Component: MIDI (Comms: System)
Revision as of 15:46, 16 February 2017 by BenR (talk | contribs) (XML import BR)
Author Matrix Ltd.
Version 1.3 (Release)
Category Comms: System
Image MIDI component
Low level routines for controlling or interacting with a standard MIDI interface.
Basic example to play a series of notes getting higher in pitch and then going down in pitch. This repeats in a loop and each time the loop repeats the instrument is changed. The current note and instrument are displayed on the LCD. MIDI Test File
The MIDI component during simulation has functionality to allow it to work with MIDI synthesizers installed on your PC.
To select your software or hardware synthesizer select from the property selector.
If you don't have a MIDI interface installed then IP MIDI seems to be a good option that works well.
Once installed the MIDI output should play through your computer speakers.
The console window can be used to view the MIDI data as it is sent out and received.
The MIDI component during embedded operation will communicate using a UART serial channel. An EB021 MIDI E-block is available to allow standard MIDI cables to be connected up to a system.
SendMIDI
Sends a MIDI packet consisting of up to three bytes of information,
BYTE Status
MIDI Status Byte - Used for commands such as NoteOn, NoteOff etc.
BYTE Data1
MIDI Data Byte - Used as a parameter specific to the specified command
BYTE Data2
SendPitchChange
Sends out a pitch change command on the specified channel.
BYTE Channel
Channel to send the pitch change to
UINT Pitch_Change
New pitch value to use, Default 0x2000
SendNoteOff
Sends a note off command using the channel, note and velocity specified.
BYTE Channel
BYTE Note
BYTE Velocity
SendControl
Sends a control command using the channel, controller and value specified.
BYTE Channel
BYTE Controller
BYTE Value
SendNoteOn
Sends a note on command using the channel, note and velocity specified.
BYTE Channel
BYTE Note
BYTE Velocity
ReceiveMIDI
Waits for the time specified in the timeout parameter for an incoming MIDI message.
Returns 0 to indicate a timeout, otherwise returns the first value from the MIDI message.
BYTE Timeout
BYTE
SendPolyPressure
Sends a note press with an associated polyphonic pressure value.
BYTE Channel
BYTE Note
BYTE Pressure
ReadData
BYTE Idx
BYTE
SendPatch
BYTE Channel
BYTE Instrument
SendChannelPressure
BYTE Channel
BYTE Pressure
Initialises the MIDI component and sets up the UART.
This macro has no parameters
Simulation macro reference
This property is of type Fixed list of ints and can be referenced with the variable name CHANNEL.
TX
This property is of type Single digital pin and can be referenced with the variable name TX.
RX
This property is of type Single digital pin and can be referenced with the variable name RX.
Data Source
This property is of type Fixed list of ints and can be referenced with the variable name DataSource.
Simulation data source used to allow the component to connect to specific MIDI hardware or the the data injector components.
Injector
This property is of type Fixed list of ints and can be referenced with the variable name Injector.
Lists all the current injector components available on the user's panel
